1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE:How to disable sequencer output at startup?
To: "Zelazny, Michael Stanley" <[email protected]>, Benjamin Franksen <[email protected]>, EPICS mailing list <[email protected]>
Date: Tue, 24 May 2016 09:13:11 +0000
Thanks for your answer.
errlogSetSevToLog(1) doesn't switch off sequencer output.
eltc(0) seems the default configuration. Setting eltc(1) makes some drivers in verbose mode.
I tried "seq ... > myfile" : only the last message is put inside the file. All PV details are displayed on console...
It seems that the seq command use the "seqcar" command which doesn't matter of output or log settings.
Any other ideas?
Thanks.
De : Zelazny, Michael Stanley [[email protected]]
Envoyé : jeudi 19 mai 2016 02:15
À : Benjamin Franksen; Touchard Dominique; EPICS mailing list
Objet : RE: How to disable sequencer output at startup?
Hi Ben,
I'm not familiar with errlogSetSevToLog but I am with eltc.  They seemingly do the same thing,
>help eltc
eltc (0,1)=>(false,true)
Mike
From: [email protected] [[email protected]] on behalf of Benjamin Franksen [[email protected]]
Sent: Wednesday, May 18, 2016 07:23
To: Touchard Dominique; EPICS mailing list
Subject: Re: How to disable sequencer output at startup?
Am 17.05.2016 um 14:33 schrieb Touchard Dominique:
> If wonder if sequencer screen output could be disabled at startup?
The sequencer runtime uses the EPICS errlog facility for output, so you
could say
in order to (globally) suppress messages that are merely informative
(the default is to log everything i.e. errlogSetSevToLog(0)).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
Re: How to disable sequencer output at startup? Benjamin Franksen
How to disable sequencer output at startup? Touchard Dominique
RE: How to disable sequencer output at startup? Zelazny, Michael Stanley
Prev: EPICS V4 Training at Lund Colaboration meeting david.hickin
Next: Re: ABS() in calc record Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: How to disable sequencer output at startup? Zelazny, Michael Stanley
Next: Re: How to disable sequencer output at startup? Benjamin Franksen
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
