1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error msg
To: <[email protected]>
Date: Fri, 3 Jun 2016 09:53:09 -0500
On 06/03/2016 09:22 AM, Dirk Zimoch wrote:
> I found _ZNSt9exceptionD2E (or demangled std::exception::~exception) in
> libstdc++.a in vxWorks 6.2, 6.3, 6.4, 6.6 and 6.7 (all vxWorks 6 I
> have). So If you include full C++ support in vxWorks, you should have it.
> __gxx_personality_v0 is also in libstdc++.a but only in vxWorks 6.7.
> VxWorks 6.2 - 6.6 have __gxx_personality_sj0.
> So If you have vxWorks 6.7 (or maybe higher) with C++ included, you
> should have the symbols.
... but the implication of the missing __gxx_personality_v0 symbol could
be that you're trying to load an executable compiled for VxWorks 6.7 or
later on an earlier version of VxWorks. That's the most common problem I
find when I see these kinds of errors.
- Andrew
>>> /ld 0,0, "app1.munch"/
>>> /Warning: module 0x23da5d0 holds reference to undefined symbol
>>> _ZNSt9exceptionD2E/
>>> /v./
>>> __gxx_personality_/
>>> /v0./
>>> /ld(): module contains undefined symbol(s) and may be unusable./
>>> /value = 0 = 0x0/
Error msg Stefen Paul
Re: Error msg Dirk Zimoch
Prev: Re: Error msg Dirk Zimoch
Next: Re: Error msg Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Error msg Stefen Paul
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
