1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions about devIocStats on vxWorks
To: Mark Rivers <[email protected]>, Stephanie Allison <[email protected]>
Date: Fri, 3 Jun 2016 12:50:34 -0500
Hi Mark,
On 06/03/2016 12:16 PM, Mark Rivers wrote:
> casr showed some things like this that look suspicious?
> TCP 164.54.160.93:51762(Ferrari): User="XAS_User", V4.13, 677 Channels,
> Priority=0
>       Task Id=0x7a24820, Socket FD=75
>       Secs since last send 593.58, Secs since last receive 593.58
>       Unprocessed request bytes=16, Undelivered response bytes=5192
>       State=up jumbo-send-buf
> Any ideas, and things to look at if I am able to reproduce the problem?
This might be a hung client program which would explain the problem, do
you recognize it? Look for the CA client running on Ferrari with a TCP
socket open on port 51762 (hint below).
In general to find hung clients you can run inetstatShow and look for
TCP connections that have large numbers in the Send-Q column, then go
and identify the specific client with that connection. You will have to
do that through the port number in the "Foreign Address" column, and
find which process on that workstation actually has a TCP socket open
with that port number; on Linux the 'lsof' program can do this if you
can login as the same user as the client or as root, although the
arguments to lsof are rather obscure (try 'lsof -i4:5064 -Tqs').
- Andrew
Questions about devIocStats on vxWorks Mark Rivers
Prev: Questions about devIocStats on vxWorks Mark Rivers
Next: Problem in updating EGU field in CSS-BOY Shantonu Sahoo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Questions about devIocStats on vxWorks Allison, Stephanie
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
