1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS connect to PLC:Illegal field value PV ;Connection timed out
To: [email protected]
Date: Sat, 18 Jun 2016 16:12:24 +0800 (GMT+08:00)
Hello sir,
  I used the driver package  s7plc.tgz from PSI and tried to connetct the EPICS IOCsoft and siemens PLC317-2PN/DP  with TCP protocol. When the IOC starts, the problems like these followed:
Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type
Illegal field value PV: ai-int16-1 s7plcGetInIntInfo: uninitialized record
s7plcReceiveThread Testsystem:0: read error after 0 of 10 bytes: Connection timed out
Is the cause of the problems the ioc failed to connect with PLC? Or there are other reasons?
Thank you.
Look forward to your answer.
Best regards,
Jie Xu
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocfirstIocboot")
epicsEnvSet("TOP","/home/newuser/EPICS/base-3.16.0.1/support")
epicsEnvSet("EPICS_BASE","/home/newuser/EPICS/base-3.16.0.1")
cd "/home/newuser/EPICS/base-3.16.0.1/support"
dbLoadDatabase "dbd/firstIoc.dbd"
firstIoc_registerRecordDeviceDriver pdbbase
var s7plcDebug 1
s7plcConfigure Testsystem:0,192.168.10.152,102,10,10,1,2000,500
dbLoadRecords db/first.db
iocInit
Starting iocInit
## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$
## EPICS Base built Jun  7 2016
s7plcInit: starting main thread
s7plcMain: main thread started
s7plcMain Testsystem:0: Connect to 192.168.10.152:102 on socket 5
s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=102
s7plcMain Testsystem:0: starting send thread Testsystem:0S
s7plcMain Testsystem:0: starting recv thread Testsystem:0R
s7plcSendThread Testsystem:0: started
s7plcReceiveThread Testsystem:0: started
## Start any sequence programs
#seq sncxxx,"user=newuser"
epics> s7plcWaitForInput Testsystem:0: select(5, 2.000000 sec) timed out
first.db
record (ai, "ai-int16-1") {
  # map range 0 ... 1000 to 0.0000 ... 10.0000
  field (DTYP, "S7plc")
  field (INP,  "@Testsystem:0/0 'T=INT16 L=0 H=1000'")
  field (EGUF, "10")
  field (LOPR, "-10")
  field (HOPR, "10")
  field (LINR, "LINEAR")
  field (PREC, "2")
  field (SCAN, "I/O Intr")
    Xu Jie,
   Southwestern Institute of Physics
    Chengdu, Sichuan 610041
    China
    Email: [email protected]
    Tel: +86-28-8285-0326
Prev: Re: MCA under windows7 64-bit Hinko Kocevar
Next: Caget packet structure Stephen Molloy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
