1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Linking agains .so library on linux
To: "Madden, Timothy J." <[email protected]>
Date: Mon, 20 Jun 2016 17:18:43 +0000
You need to reference your vendor .so file using PROD_SYS_LIBS not PROD_LIBS.
Sent from my iPhone
On Jun 20, 2016, at 11:15 AM, Madden, Timothy J. <[email protected]<mailto:[email protected]>> wrote:
Dear EPICS:
I want to link an IOC against an .so supplied by a vendor. The compile seems to only look for .a type libraries.
Also I notice that on linking, -Bstatic is turned on. (I am using linux).
I have epics base CONFIG_SITE file set to:
SHARED_LIBRARIES=YES
#  Build client objects statically ?
#        must be either YES or NO
STATIC_BUILD=NO
This seems like it should work.
How do I get rid of the -Bstatuc on my link, so it will look for .so files on link?
Here is the failing command:
/usr/bin/g++ -o pcoApp -Wl,-Bstatic -L/local/pco/EPICS/base-3.14.12.5/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCameralink/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCore/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/areaDetector/ADPCO/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/asyn4-26/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/autosave-4-7/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/busy-1-3/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/calc-2-8/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/caputRecorder-1-4-2/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/seq-2-2-3/lib/linux-x86_64 -L/local/pco/EPICS/synApps_5_5/support/sscan-2-6-6/lib/linux-x86_64 -L/local/pco/hdf/lib -L/local/pco/sisw/lib64 -L/local/pco/szip/lib -Wl,-rpath,/local/pco/EPICS/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCamer!
 alink/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/areaDetector/ADPCO/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/asyn4-26/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/autosave-4-7/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/busy-1-3/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/calc-2-8/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/caputRecorder-1-4-2/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/seq-2-2-3/lib/linux-x86_64 -Wl,-rpath,/local/pco/EPICS/synApps_5_5/support/sscan-2-6-6/lib/linux-x86_64 -Wl,-rpath,/local/pco/hdf/lib -Wl,-rpath,/local/pco/sisw/lib64 -Wl,-rpath,/local/pco/szip/lib        -m64                pcoApp_registerRecordDeviceDriver.o pcoAppMain.o   -lpco -lcameralink -lcaputRecorder -lclsersis -lNDPlugin -lADBase -lnetCDF -lNeXus -lca!
 lc -lbusy -lsscan -lautosave -lasyn -lseq -lpv -lrecIoc -lsoft!
 DevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lhdf5 -lsz -Wl,-Bdynamic -ltiff -ljpeg -lxml2 -lz -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lclsersis
collect2: ld returned 1 exit status
Tim Madden
Argonne
RE: Linking agains .so library on linux Madden, Timothy J.
Prev: Linking agains .so library on linux Madden, Timothy J.
Next: Re: Linking agains .so library on linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Linking agains .so library on linux Madden, Timothy J.
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
