1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Archiver Appliance stuck in "Initial sampling" state
To: <[email protected]>
Cc: [email protected]
Date: Wed, 22 Jun 2016 10:50:43 +0000
Hello Murali,
Yes that works! My problem came from the appliance.xml file setupscript made. In the setupscript it reads:
                                FQ_HOSTNAME=`hostname -f`
# Create an appliances.xml file and set up this appliance's identity.
                                cat > ${DEPLOY_DIR}/appliances.xml <<EOF
<appliances>
   <appliance>
     <identity>appliance0</identity>
     <cluster_inetport>${FQ_HOSTNAME}:16670</cluster_inetport>
     <mgmt_url>http://${FQ_HOSTNAME}:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://${FQ_HOSTNAME}:17666/engine/bpl</engine_url>
     <etl_url>http://${FQ_HOSTNAME}:17667/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://${FQ_HOSTNAME}:17668/retrieval</data_retrieval_url>
   </appliance>
</appliances>
EOF
In the quickstart script it reads:
cat > "${ARCHAPPL_APPLIANCES}" <<EOF
<appliances>
   <appliance>
     <cluster_inetport>localhost:16670</cluster_inetport>
     <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://localhost:17665/engine/bpl</engine_url>
     <etl_url>http://localhost:17665/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17665/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://${FQ_HOSTNAME}:17665/retrieval</data_retrieval_url>
   </appliance>
</appliances>
EOF
On the bold line in the setupscript is gives localhost and on the other lines it uses the hostname (which didn’t work on this default linux setup). I put everything to “localhost” by copying the Quickstart “appliance.xml” and then I broke the port numbers. After putting the portnumbers back and changing everything to localhost, it started to archive. I guess that I should sort out the hostname on this VM but I believe that caused this issue.
Best regards,
Rory
Rory Clarke
Electrical and Controls Systems Group
Daresbury Laboratory
Keckwick Lane
Warrington
Cheshire
WA4 4AD
E: [email protected]
T: 01925 60 Ext. 3172
Sent: 21 June 2016 19:45
To: Clarke, Rory (STFC,DL,TECH)
Subject: Fw: Archiver Appliance stuck in "Initail sampling" state
Apologies; forgot to cc you.
Murali
Sent: Tuesday, June 21, 2016 11:39 AM
To: [email protected]
Subject: Re: Archiver Appliance stuck in "Initail sampling" state
>> I also changed the  “appliance.xml” file to match the quickstart demo version
The quickstart.sh and single_machine_install.sh are fundamentally two different deployment models. The "quickstart.sh" runs all the WAR files in a single Tomcat instance; thus all the ports in your appliance.xml will be 17665.
The "single_machine_install.sh" uses four separate tomcat instances; one each for each of the components.  Your "sampleStartup.sh" will start up four different tomcat's; each of which listen on different ports. This is probably the reason why you are getting this exception
java.io.IOException: Invalid status calling http://localhost:17665/engine/bpl/getVersion. Got 404Not Found
I would first try to reuse you original appliances.xml. Make sure the four component start up correctly without exceptions first.
If you need more help, ping feel free to ping me offline.
Murali
Prev: Re: IOCs under procServ as system services under systemd? S. Banerian
Next: streams drivers Peter Blanco
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Archiver Appliance stuck in "Initail sampling" state Shankar, Murali
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
