Hi Andrew,
> Thanks. Doesn't the "user=carepeater" parameter mean that there must
> be a username called carepeater that is used just to run the
> repeater? I would probably default to something like daemon instead.
I usually create a separate user for each daemon. But using "daemon"
sounds more reasonable for a file that ships with EPICS Base.
>> Are you suggesting to replace the caRepeater autostart
>> functionality by systemd's socket activation in the long run?
> Not replacing it (we will always need it to autostart for when an IOC
> is running on an embedded system say), but adding the ability to use
> socket activation when desired would make sense.
I see. Unfortunately I don't have time to add that feature right now but
it shouldn't be too hard to do. See [1] for a nice description of
systemd's socket activation including some example code.
Cheers,
Martin
[1] http://0pointer.de/blog/projects/socket-activation.html
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
- Re: IOCs under procServ as system services under systemd? Jack
- IOCs under procServ as system services under systemd? Ralph Lange
- Re: IOCs under procServ as system services under systemd? Niklas Claesson
- Re: IOCs under procServ as system services under systemd? Konrad, Martin
Re: Including libraries in subroutines Stephen Molloy
EPICS Website downloads Andrew Johnson
<2016>
Re: IOCs under procServ as system services under systemd? Andrew Johnson
<2016>
