1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unreachable code in makeBaseApp.pl?
To: <[email protected]>
Date: Thu, 7 Jul 2016 17:57:13 -0500
Hi Stephen,
On 07/07/2016 09:45 AM, Stephen Molloy wrote:
> While building Docker containers, I had an error that turned out to be
> due to the lack of a $USER environment variable.  When makeBaseApp.pl is
> called, it tries to figure out the username in the GetUser subroutine,
> using the following command:
> $user= $opt_u|| $ENV{USER}|| $ENV{USERNAME}|| Win32::LoginName();
I agree that doesn't look terribly robust, but for a Linux environment
to not define $USER seems rather unusual. Does this one-liner output the
username correctly?
  perl -e 'printf "%s\n", getlogin();'
> Of course, it’s very possible that this issue is caused by something
> that I am doing wrong….
I'm wondering why you're using makeBaseApp.pl from inside a docker
container, and why it isn't setting $USER, but that's more from curiosity...
- Andrew
Unreachable code in makeBaseApp.pl? Stephen Molloy
Prev: Unreachable code in makeBaseApp.pl? Stephen Molloy
Next: Re: Unreachable code in makeBaseApp.pl? Stephen Molloy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
