1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to configurate MCA for Octave
To: Hulusi Öz <[email protected]>
Cc: [email protected]
Date: Thu, 21 Jul 2016 09:17:45 -0700
Your first message showed that make was trying to invoke ‘mex’.  This is not proper for octave.  The shell script I sent arranges for make to run the mkoctfile utility that is appropriate for octave.
Make sure too that your octave executables are on your shell search path:
enorum 205>  type octave mkoctfile
octave is /usr/bin/octave
mkoctfile is /usr/bin/mkoctfile
What commands are you running?   It sounds like you tried running ‘make’ again — this is incorrect.  You should run the script which will set things up as required by octave and then run make.
Please send the entire set of commands you are running and the resulting output.
On Jul 21, 2016, at 9:10 AM, Hulusi Öz <[email protected]> wrote:
It doesn't work for me. I'm still getting same error..
2016-07-21 18:53 GMT+03:00 Eric Norum <[email protected]>:
You must set the EPICS_BASE and EPICS_EXTENSIONS environment variables and then run the buildForOctave.sh script.  I just tried this on a Linux machine here and all seems to work:
enorum 201> cd /usr/local/epics/R3.14.12/extensions/src/mca
enorum 202> export EPICS_EXTENSIONS=/usr/local/epics/R3.14.12/extensions
enorum 203> export EPICS_BASE=/usr/local/epics/R3.14.12/base
enorum 204> sh buildForOctave.sh
mkoctfile --mex -DmexAtExit=atexit -v -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DEPICS_DLL_NO -L/usr/local/epics/R3.14.12/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -o O.linux-x86_64/mca.mex
g++ -c -fPIC -I/usr/include/octave-3.4.3/octave/.. -I/usr/include/octave-3.4.3/octave -I/usr/include/freetype2 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DmexAtExit=atexit -DEPICS_DLL_NO mca.cpp -o mca.o
In file included from mca.cpp:24:
Channel.h: In member function 'char* Channel::GetHostName() const':
Channel.h:29: warning: deprecated conversion from string constant to 'char*'
g++ -c -fPIC -I/usr/include/octave-3.4.3/octave/.. -I/usr/include/octave-3.4.3/octave -I/usr/include/freetype2 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DmexAtExit=atexit -DEPICS_DLL_NO MCAError.cpp -o MCAError.o
g++ -c -fPIC -I/usr/include/octave-3.4.3/octave/.. -I/usr/include/octave-3.4.3/octave -I/usr/include/freetype2 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DmexAtExit=atexit -DEPICS_DLL_NO Channel.cpp -o Channel.o
In file included from Channel.cpp:4:
g++ -shared -Wl,-Bsymbolic -o O.linux-x86_64/mca.mex mca.o MCAError.o Channel.o -L/usr/local/epics/R3.14.12/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca -L/usr/lib64/octave/3.4.3 -L/usr/lib64 -loctinterp -loctave -lcruft -L/usr/lib64/atlas -llapack -L/usr/lib64/atlas -lf77blas -latlas -lfftw3 -lfftw3f -lm -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../.. -lgfortranbegin -lgfortran -lm
cp O.linux-x86_64/mca.mex /usr/local/epics/R3.14.12/extensions/lib/linux-x86_64
enorum 205>
On Jul 21, 2016, at 6:48 AM, Eric Norum <[email protected]> wrote:
Did you try using the ‘buildForOctave’ script that is distributed with the MCA extension?
#!/bin/sh
# Provided by Eric Norum, APS, Dec. 2006
if [ -z "`env | grep EPICS_BASE`" -o -z "`env | grep EPICS_EXTENSIONS`" ]
then
    echo "Need EPICS_BASE and EPICS_EXTENSIONS environment variables" >&2
    exit 1
fi
MEX="mkoctfile --mex" FLAGS="-DmexAtExit=atexit" make MEXOUT=mex install
rm -f Channel.o MCAError.o TestHash.cpp mca.o
Caveat — it’s been a while since I’ve used this.
On Jul 21, 2016, at 6:03 AM, Hulusi Öz <[email protected]> wrote:
Hi Everyone,
I have just installed GNU Octave on Ubuntu 16.04 -x64. And also, I have just installed MCA extension. However, I could not configurate each of them . Therefore, I could not build MCA extension. I have got this error :
mex -v -I/opt/epics/base/include -I/opt/epics/base/include/os/Linux -DEPICS_DLL_NO -L/opt/epics/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -o O.linux-x86_64/mca.mexglx
make: mex: Command not found
Makefile:66: recipe for target 'O.linux-x86_64/mca.mexglx' failed
make: *** [O.linux-x86_64/mca.mexglx] Error 127
How can I figure this error out ? I am looking forward to your recommendations..
Thanks in advance,
Best Regards..
Hulusi
Eric Norum
[email protected]
Eric Norum
[email protected]
Eric Norum
[email protected]
How to configurate MCA for Octave Hulusi Öz
Re: How to configurate MCA for Octave Eric Norum
Re: How to configurate MCA for Octave Hulusi Öz
Prev: Re: How to configurate MCA for Octave Hulusi Öz
Next: Re: How to configurate MCA for Octave Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 21 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
