1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Inconsistency in devAsynOctet for stringout and waveform records
Cc: "[email protected] list" <[email protected]>
Date: Sat, 23 Jul 2016 15:51:23 -0700
I think that the question is, “Why does caput -S include the trailing NUL?”.
The existing stringout and waveform record behaviour seems right.  A CHAR waveform record can’t till if it is being called on to send ‘long’ strings or arbitrary single-byte data so if told to send N bytes it should do so — it certainly should not try to outguess the caller by looking at the final byte and not sending it if it happens to be ‘\0’.
On Jul 22, 2016, at 1:55 PM, Mark Rivers <[email protected]> wrote:
Hi Eric and Andrew (and others),
I have just found an inconsistency in the devAsynOctet.c for handling string output for stringout records versus waveform records.
I have a stringout record which I process as follows:
caput SIM1:SOHigh "abc"
This is the output of devAsynOctet.c with some debugging statements added:
devAsynOctet::callbackSoWrite, calling writeIt with message="abc", nbytes=3
This is what happens when I write the same string with a waveform record:
caput -S SIM1:WFOutHigh "abc"
devAsynOctet::callbackWfWrite, calling writeIt with message="abc", nbytes=4
So in the case of the stringout record the length being passed to the driver is strlen() of the string, while for the waveform record it is the NORD field of the waveform record.  NORD includes the terminating 0 byte.
This difference in behavior is causing me problems when extending the Modbus driver to handle strings.
Which do you feel is the “correct” behavior?  Should the driver be called with nbytes including the trailing 0 or not?
RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Prev: Re: Inconsistency in devAsynOctet for stringout and waveform records Torsten Bögershausen
Next: RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
ANJ, 23 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
