1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: may I start a pcaspy ioc together with a streamdevice ioc?
To: tech-talk <[email protected]>
Date: Mon, 25 Jul 2016 19:34:01 +0800
hi, all
  I have a normal streamdevice ioc which controls power supply via ethernet. Now I want to add a function to send large waveform data (about 10000 floats) to power supply. If I just use streamdevice to transfer the data, the speed is slow and can't satisfy my requriement.
  I with to use pcaspy to creat another ioc as it can supply a pv to a client, for example, which inform to send data by a pv write, then the pcaspy ioc will send the data to power supply by ethernet. so I have two questions:
1. how to use the same socket of streamdevice? power supply controller has only one socket server. (during data transfer, I can stop the streamdevice db processing)
2. how to hook up the pcaspy ioc together with streamdevice ioc? (if I don't want to use procServ or inet, etc.)
  thanks a lot for your help.
Best wishes
Geyang 2016-07-25
RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
Prev: areaDetector with 'empty' array output Phil Atkin
Next: RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector with 'empty' array output Andrew Johnson
ANJ, 25 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
