1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NDArrayPool::alloc failing
To: [email protected]
Date: Fri, 29 Jul 2016 10:37:17 -0400
On 07/29/2016 09:29 AM, Mark Rivers wrote:
> We could add an NDArray::getReferenceCount method.  If you have the array reserved and getReferenceCount=1 then you can be sure all the plugins have released it.
A good interface to handle this sort of situation would be for
NDArrayPool::alloc() to accept a callback function pointer to "cleanup"
the user provided buffer when the NDArray ref. count falls to zero.
RE: NDArrayPool::alloc failing Mark Rivers
NDArrayPool::alloc failing Phil Atkin
Re: NDArrayPool::alloc failing Phil Atkin
Prev: Re: NDArrayPool::alloc failing Phil Atkin
Next: shell command in medm Li, Yuelin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: NDArrayPool::alloc failing Mark Rivers
Next: RE: NDArrayPool::alloc failing Mark Rivers
ANJ, 12 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
