Hi, I am trying to use ADPluginEdge with the sim detector and I run into the following error: make[6]: Entering directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/si mDetectorNoIOC/simDetectorNoIOCApp/src/O.windows-x64' cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_ SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 -DH5 _BUILT_AS_STATIC_LIB /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I.. -I. .\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -I..\\..\\..\\..\\..\\inclu de -IC:\Epics\base-3.14.12.5\\include\\os\\WIN32 -IC:\Epics\base-3.14.12.5\\ include -IC:\Epics\support\\asyn-4-29\\include -IC:\Epics\support\areaDetector- 2-5\\ADBinaries\\include\\os\\WIN32 -IC:\Epics\support\areaDetector-2-4\\ADBinar ies\\include -IC:\Epics\support\areaDetector-2-4\\ADCore\\include\\os\\WIN32 -IC :\Epics\support\areaDetector-2-4\\ADCore\\include -IC:\Epics\support\\autosave-5 -7-1\\include\\os\\WIN32 -IC:\Epics\support\\autosave-5-7-1\\include -IC:\Epics \support\\busy-1-6-1\\include -IC:\Epics\support\\calc-3-2\\include -IC:\Epics \support\\seq-2-1-18\\include -IC:\Epics\support\\sscan-2-10-1\\include -IC:\Ep ics\support\\devIocStats-3-1-14\\include\\os\\WIN32 -IC:\Epics\support\\devIocSt ats-3-1-14\\include -IC:\Epics\support\\caPutLog-3-4\\include -I\\usr\\lo cal64\\include -I\\usr\\include\\libxml2 ..\\simDetectorNoIOC.cpp simDetectorNoIOC.cpp make[6]: *** No rule to make target `../../../lib/windows-x64/opencv_world310.li b', needed by `simDetectorNoIOCApp.exe'. Stop. make[6]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim DetectorNoIOC/simDetectorNoIOCApp/src/O.windows-x64' make[5]: *** [install.windows-x64] Error 2 make[5]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim DetectorNoIOC/simDetectorNoIOCApp/src' make[4]: *** [src.install] Error 2 make[4]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim DetectorNoIOC/simDetectorNoIOCApp' make[3]: *** [simDetectorNoIOCApp.install] Error 2 make[3]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim DetectorNoIOC' make[2]: *** [simDetectorNoIOC.install] Error 2 make[2]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs' make[1]: *** [iocs.install] Error 2 make[1]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample' make: *** [C:\Epics\support\areaDetector-2-4/ADExample.install] Error 2 To get it to compile and the plugin to work with the simDetector, I am manually copying the opencv_world310.lib file in the $(ADExample)/lib/$(EPICS_HOST_ARCH) directory. my CONFIG_SITE.local has opencv location defined as: OPENCV = C:/opencv-3.1 OPENCV_LIB = $(OPENCV)/build/x64/vc12/lib OPENCV_INCLUDE = -I$(OPENCV)/build/include/ and the commonDriverMakefile has the following defined: ifdef ADPLUGINEDGE PROD_LIBS += NDPluginEdge $(PROD_NAME)_DBD += NDPluginEdge.dbd ifdef OPENCV_LIB opencv_core_DIR += $(OPENCV_LIB) PROD_LIBS += opencv_world310 else PROD_SYS_LIBS += opencv_world310 endif endif Is there something else I need to add/change to get it to compile properly? Thanks Best, Ali
ANJ, 03 Aug 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
