1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Drawing on XY graph widget without the use of a PV in CSS
Date: Mon, 8 Aug 2016 11:30:34 +0000
Hello
Is it possible to draw some data on an XY graph widget from a script/rule without using a PV? I mainly tried setting the property 'pv_value' but nothing appears on the graph. I'm not sure if this is even possible or not. The thing is I will receive a waveform PV value and I want to do some processing on it then displaying the output on the XY graph.
Best Regards,
Abdalla.
Prev: Re: Epics-Digitizer Communication Hulusi Öz
Next: Re: CA connection problems between VxWorks and Windows Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error in interfacing gigE camera make: Balser Mark Rivers
Next: Re: Drawing on XY graph widget without the use of a PV in CSS Márcio Paduan Donadio
ANJ, 08 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
