Hi Bill,
On 08/10/2016 06:22 PM, Lee, William R. (LARC-D304)[Jacobs Technology,
Inc.] wrote:
> I am trying to build EPICS base-3.15.4 on Windows 10 (64-bit) using
> Visual Studio 10. The build fails with the following messages:
> make[3]: *** No rule to make target '../../../lib/windows-x64/Com',
> needed by 'iocLogServer.exe'. Stop.
This is strange; normally at that point in the build process instead of
iocLogServer.c the source files that make up the libCom library
(Com.dll) get compiled, and then the library itself is constructed. You
can see that in the output from the Jenkins build job at
https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/256/consoleFull
> I've included artifacts below which I hope will be helpful in diagnosing
> my problem(s):
They were helpful, thanks.
Is it possible that your initial 'make clean uninstall' did not actually
cause an older bin/windows-x64/Com.dll file to be deleted?
If caRepeater.exe is still running in the background, the libraries it
depends on cannot be removed, and this might have the effect you're
seeing. I usually use 'make distclean' instead, which fails when it
can't delete the non-empty bin/ directory, but I'm not sure whether the
uninstall target will fail in the same way or not.
I can't think of any other explanation at this point, please write back
to tech-talk if this doesn't help though as others here may have more ideas.
- Andrew
- RE: building EPICS base-13.15.4 on Windows 10 Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]
- building EPICS base-13.15.4 on Windows 10 Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]
Re: Race condition in db_get_field_and_count() (3.14.12) Andrew Johnson
Re: Race condition in db_get_field_and_count() (3.14.12) Williams Jr., Ernest L.
<2016>
2025
<2016>
2025
