1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is it possible for channel access to send duplicates?
To: <[email protected]>
Date: Fri, 12 Aug 2016 15:10:18 -0500
Hi Dehong,
On 08/12/2016 02:48 PM, Zhang, Dehong wrote:
> Is it possible that the channel access server may send duplicates,
> or re-transmit the same messages?  Specially when congested?
The CA server gets informed of value updates by the data source (a
database record for an IOC server, some other software for a CAS server)
and queues each update to be forwarded over TCP once to each subscribed
client. If there is congestion some individual value updates may be
dropped from the queue (and since different clients will accept data at
slightly different rates different updates may be dropped), but the
client should never see duplicates.
Note that if a channel sends a series of updates with values A, B, A, B
and one of the B values gets dropped it may appear that an A was
duplicated, but that wasn't what actually happened. You may be able to
use time-stamps to distinguish that case, providing the source of time
increments fast enough that each value update gets a different
time-stamp; a VxWorks IOC that just relies on the 60 Hz tick interrupt
for its clock probably won't be fast enough for that.
The CA protocol never sends value updates over UDP, so Michael's point
that UDP packets can be duplicated by the network isn't really relevant
here (it does apply to CA name searches and beacons, but those are
hidden from the client application by the CA library anyway).
HTH,
- Andrew
Is it possible for channel access to send duplicates? Zhang, Dehong
Prev: Re: Is it possible for channel access to send duplicates? Kasemir, Kay
Next: Question about data display in css boy opi databrowser lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 13 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
