1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: installation of synapps_5_8 in ubuntu
To: "Mark Rivers" <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Aug 2016 17:04:34 +0530
I am having a 32-bit linux.
> ---------------------------- Original Message ----------------------------
> From:    "Mark Rivers" <[email protected]>
> Date:    Tue, August 16, 2016 4:56 pm
> To:      "[email protected]" <[email protected]>
> Are you running a 32-bit or 64-bit version of Linux?  You are building the
> 32-bit version of EPICS (linux-x86).  If you have a 64-bit Linux system it
> is possible that you are missing some 32-bit libraries and you should do
> the following
> export EPICS_HOST_ARCH=linux-x86_64
> Then you will be building for 64-bit EPICS.  See if that also gets an
> error.
> Mark
> From: [email protected] [[email protected]] on
> behalf of Mark Rivers [[email protected]]
> Sent: Tuesday, August 16, 2016 6:17 AM
> To: [email protected]; [email protected]
> You should send the complete output when you build in the autosave
> directory
> make clean uninstall
> make
> Mar
> behalf of [email protected] [[email protected]]
> Sent: Tuesday, August 16, 2016 6:11 AM
> Subject: installation of synapps_5_8 in ubuntu
> Hi,
>   I have copied synapps_5_8 under '/opt/epics'.
> epics-base is already build under /opt/epics/base-3.15.3
> msi is under /opt/epics/extensions/src/msi1.7
> When I am trying to build synapps with areaDetector by using 'make'
> command
> I am getting following errors.
> /opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86/libautosave.so:
> undefined reference to `_dl_sysinfo'
> undefined reference to `__syscall_error'
> collect2: error: ld returned 1 exit status
> I am new to linux and could not get any suggestions from google.
> Please help me
> Thank you.
installation of synapps_5_8 in ubuntu avanish
RE: installation of synapps_5_8 in ubuntu Mark Rivers
Prev: RE: installation of synapps_5_8 in ubuntu Mark Rivers
Next: RE: installation of synapps_5_8 in ubuntu avanish
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
