1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Is There A Way to Explicitly Close CA Connections in PyEpics?
To: tech-talk <[email protected]>
Date: Thu, 18 Aug 2016 12:21:20 -0400 (EDT)
Hello,
I am writing a Python (2.7.5) program and are using PyEpics in the program.  I wanted to explicitly close the CA connections after I created and used them, but found that once a CA connection was created, it stayed connected (the ioc server was up) until the program exited, and there seems to be no way to close it explicitly in the program.  I am new to the PyEpics and appreciate any help.
I tried epics.caget(); it created the CA connection and the connection stayed open until the program exited.
I tried pv = epics.PV() and then pv.disconnect(); the disconnect() method closed all the event monitors on the pv, but did not close the connection.
I tried epics.ca.create_channel() and then epics.ca.clear_channel(); the clear_channel() indeed closed the CA connection.  But the problem with this approach is that the program would crash if I call epics.ca.create_channel() on the same pv again and try to get the state or value from the returned channel ID, as the following.
>>> chid = epics.ca.create_channel('xxx')
>>> epics.ca.clear_channel(chid)
1
>>> epics.ca.state(chid)
(crash!)
Finally, calling epics.ca.destroy_context() and epics.ca.create_context() after epics.ca.clear_channel() seems to allow a new connection to be created on the same pv, but that would also wipe out all the existing channels I want to keep.
I used casr on the ioc server to verify CA connections from clients.
William Lu
Re: Is There A Way to Explicitly Close CA Connections in PyEpics? Matt Newville
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
Next: Re: Is There A Way to Explicitly Close CA Connections in PyEpics? Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
ANJ, 08 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
