1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A Problem while Installing calc in synApps_5_5
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 24 Aug 2016 09:44:54 +0200
On 24/08/2016 06:41, Mooney, Tim M. wrote:
synApps_5_8 is intended to build with either 3.14 or 3.15.  (I would recommend 3.14.12.5, or 3.15.3.)  I've been regarding 3.16.0 as a development version - an early look - that is mostly intended to give EPICS application developers a target to shoot at.  I haven't actually tried in earnest to hit that target yet.
Tim is right. As I stated recently on this forum: EPICS Base versions with a zero in the update counter (e.g. 3.15.0, 3.16.0.x) are considered by the developers as "not for productional use", since they have not had the appropriate amount of testing, and other packages (modules, extensions, applications) have not been compiled and tested against them.
However, the development versions of Base do provide an opportunity for maintainers of other modules to compile against and test, so that remaining bugs in Base can be found and fixed before the first "real" version is released, and the new release series gets supported quickly.
The synApps bundle is a special case, because - as a bundle - it requires all its packages support a new base release series before it can bundle them.
As for the original question:
Please use the 3.15 "current" release series of Base that is supported by synApps.
Cheers,
~Ralph
A Problem while Installing calc in synApps_5_5 정필규
RE: A Problem while Installing calc in synApps_5_5 Mooney, Tim M.
Prev: RE: tpmac distribution ulrik.pedersen
Next: Re: EPICS and TIA Portal communication Nick Levchenko
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: A Problem while Installing calc in synApps_5_5 Mooney, Tim M.
Next: [no subject] Paramveer Jain
ANJ, 24 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
