1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: Eric Norum <[email protected]>
Date: Thu, 25 Aug 2016 18:44:49 -0500
That’s strange… I’m running OpenMotif 2.3.4 via HomeBrew with MEDM without any problem on my Mac.  As I recall, all I had to do was to install OpenMotif (and any other things I needed for MEDM).  I’m running on El Capitan, if that makes any difference.  As far as I can tell anything I can make MEDM do, so far, it has been working fine…
I will check, however, if there is any hints to your problem, at least with respect to MEDM.
On Aug 25, 2016, at 6:35 PM, Eric Norum <[email protected]> wrote:
I recently switched from MacPorts to homebrew.  As a result my system now has a more recent version of OpenMotif — 2.3.4.  This seems to have broken medm and edm.
They build fine, but attempting to run them results in:
eric 570> edm
Error: attempt to add non-widget child "dsm" to parent "edm" which supports only widgets
eric 571> medm
MEDM Version 3.1.9: Loading aliased fonts.................
SIGSEGV
Abort trap: 6
Suggestions from any X11 experts out there?  I’d hate to have to fall back to MacPorts since homebrew has a lot of other packages, octave being one of the more important, that are much more up to date.
I tried installing and building with lesstif (0.95.2) instead, but that just results in:
eric@33 585> edm
Warning: translation table syntax error: Unknown event type :   EnterWindow
Warning: ... found while parsing '<EnterWindow>:            ManagerEnter()'
Warning: String to TranslationTable conversion encountered errors
Warning: XmManager ClassInitialize: XmeTraitSet failed
Warning: translation table syntax error: Unknown event type :   MapNotify
Warning: ... found while parsing '<MapNotify>:              SWNoop()'
Error: Unresolved inheritance operation
eric@33 586> medm
SIGBUS
Abort trap: 6
Eric Norum
[email protected]
Re: OS X edm/medm openmotif woes Eric Norum
Prev: OS X edm/medm openmotif woes Eric Norum
Next: Re: OS X edm/medm openmotif woes Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 25 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
