1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: Eric Norum <[email protected]>
Date: Fri, 26 Aug 2016 09:54:34 -0500
On 08/25, Eric Norum wrote:
> I recently switched from MacPorts to homebrew.  As a result my system
> now has a more recent version of OpenMotif — 2.3.4.  This seems to
> have broken medm and edm.
Hi, Eric!
Slightly off-topic, but just an FYI or if you can't get it to work with
OpenMotif from Homebrew, there's also pkgsrc:
  http://pkgsrc.org/
This is what I mostly use.  (I do use Homebrew for some things.)  I
build MEDM against Motif (2.3.4) from pkgsrc which is from ICS:
  http://motif.ics.com/
Two nice things about pkgsrc are:
1. It's cross-platform.  You can use the same build system to produce
   OS X and Linux (among others) packages.  Of course, if you only need
   packages for OS X, then this isn't of any benefit, but if you do need
   packages for other platforms, then this can be a huge win in that you
   don't have to learn N packaging systems and maintain M package specs
   in N packaging systems.
2. It has a lot of packages (way more than Homebrew).
I build my packages myself, but there are binary package repositories
where you don't need to build the packages yourself.  For example, there
are repositories provided by Joyent:
  https://pkgsrc.joyent.com/
Here's Joyent's repository for Darwin x86_64:
  https://pkgsrc.joyent.com/packages/Darwin/trunk/x86_64/All/
(No octave package, though, at the moment.  A package spec exists for
it, but probably it has a build failure on Darwin x86_64, so no package
was created.)
Lewis
OS X edm/medm openmotif woes Eric Norum
Prev: asyn R4-30 available Mark Rivers
Next: Re: OS X edm/medm openmotif woes Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OS X edm/medm openmotif woes Bob Soliday
Next: EPICS driver for Mitsubishi FX3G PLC Kyle Lanclos
ANJ, 17 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
