1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: question about pcaspy
To: "Kasemir, Kay" <[email protected]>, geyang <[email protected]>
Date: Mon, 29 Aug 2016 13:03:55 +0000
> Doesn’t matter, the easiest way to configure this is still to leave EPICS_CAS_SERVER_PORT undefined
> since the clients will find all your IOCs just fine.
The only exception to this is if your clients are on a different subnet from your IOC.  In that case I believe you can use a PV gateway, or set the PCAS server port manually and set EPICS_CA_ADDR_LIST on the client.
From: [email protected] [[email protected]] on behalf of Kasemir, Kay [[email protected]]
Sent: Monday, August 29, 2016 7:45 AM
To: geyang
Cc: [email protected]
Subject: Re: question about pcaspy
Hi:
If you want to run multiple copies of the pcaspy CA server on one computer, it’s really the same as running multiple soft IOCs on the same computer.
You don’t need to change any port settings.
All copies of the CA server on the host will listen to UDP name searches on the default UDP port.
They cannot all use the same default TCP port, so except for the first server that you start you’ll see the warning messages “css warning: Configured TCP port was unavailable. Using dynamically assigned ..” but that’s not a problem.
What happens on the protocol level:
Clients search for a channel.
CAS replies: I have that channel, talk to me on TCP port xxxxxx.
For the first CAS that you start, that TCP port is the default, for the rest it’s a different port.
Doesn’t matter, the easiest way to configure this is still to leave EPICS_CAS_SERVER_PORT undefined since the clients will find all your IOCs just fine.
See also https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Configure_Channel_Access<redir.aspx?REF=K4w4oV4e7nMp4yQsH0uQtCKJQEqNIdY2XwxaEpynxnFy8TKhDNDTCAFodHRwczovL3dpa2ktZXh0LmFwcy5hbmwuZ292L2VwaWNzL2luZGV4LnBocC9Ib3dfdG9fQ29uZmlndXJlX0NoYW5uZWxfQWNjZXNz>
-Kay
On Aug 27, 2016, at 8:45 PM, geyang <[email protected]<redir.aspx?REF=NLRaXEcDSU9WoIHBsGBGzIvQzStBK08Uw7P2t--m2ahy8TKhDNDTCAFtYWlsdG86bWFyY29faGFpckAxNjMuY29t>> wrote:
hi,
  I would like to ask if  SimpleServer's port can be changed to others in code, such as 5066/5068? For example, I have a device driver written by pcaspy, I want to implement the same driver for many same type devices on one machine, then I need to set them different server ports.
  thanks a lot for your help.
Best wishes
Geyang 2016/8/28
Re: question about pcaspy Ralph Lange
question about pcaspy geyang
Re: question about pcaspy Kasemir, Kay
Prev: Re: question about pcaspy Kasemir, Kay
Next: Re: question about pcaspy Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
