1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ether_ip linking issue in epics base-3.15
To: "Kim, Kukhee" <[email protected]>
Date: Thu, 1 Sep 2016 13:25:52 +0000
Hi:
> On Aug 31, 2016, at 6:40 PM, Kim, Kukhee <[email protected]> wrote:
> ..softDevIoc and testDevIoc ..
> We don't need to put the individual libraries in the Makefile.
> We can just use "eipIoc_LIBS += $(EPICS_BASE_IOC_LIBS)".
> The macro contains everything what we need to build an ioc.
You’re right!
I’ve updated the makefile, actually removing recIoc as well, since it’s also included in EPICS_BASE_IOC_LIBS.
Kay
ether_ip linking issue in epics base-3.15 Kim, Kukhee
Prev: Re: Question about determining network connection by using different LED widget color Kasemir, Kay
Next: devlib2 release 2.8 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: ether_ip linking issue in epics base-3.15 Kim, Kukhee
Next: Question about determining network connection by using different LED widget color lzf neu
ANJ, 01 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
