I installed VDCT with jar when I make new record its giving some error msgs as VisualDCT consoleLoading VisualDCT v2.6 build 1274... --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) o) Error occured while opening file '/opt/epics/base/dbd/Example2.vdb' java.io.FileNotFoundException: /opt/epics/base/dbd/Example2.vdb (No such file or directory) at java.io.FileInputStream.open(Native Method) at java.io.FileInputStream.<init>(FileInputStream.java:146) at java.io.FileInputStream.<init>(FileInputStream.java:101) at com.cosylab.vdct.db.DBResolver.getEnhancedStreamTokenizer(Unknown Source) at com.cosylab.vdct.db.DBResolver.resolveIncodedDBDs(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.checkForIncodedDBDs(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source) at com.cosylab.vdct.graphics.DSGUIInterface.openDB(Unknown Source) at com.cosylab.vdct.graphics.DsManager.openDB(Unknown Source) at com.cosylab.vdct.VisualDCT.openMenuItem_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC7(Unknown Source) at com.cosylab.vdct.VisualDCT.access$900(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) o) Error occured while opening file '/opt/epics/base/dbd/Example2.vdb' java.io.FileNotFoundException: /opt/epics/base/dbd/Example2.vdb (No such file or directory) at java.io.FileInputStream.open(Native Method) at java.io.FileInputStream.<init>(FileInputStream.java:146) at java.io.FileInputStream.<init>(FileInputStream.java:101) at com.cosylab.vdct.db.DBResolver.getEnhancedStreamTokenizer(Unknown Source) at com.cosylab.vdct.db.DBResolver.resolveDB(Unknown Source) at com.cosylab.vdct.db.DBResolver.resolveDB(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.open(Unknown Source) at com.cosylab.vdct.graphics.DSGUIInterface.openDB(Unknown Source) at com.cosylab.vdct.graphics.DsManager.openDB(Unknown Source) at com.cosylab.vdct.VisualDCT.openMenuItem_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC7(Unknown Source) at com.cosylab.vdct.VisualDCT.access$900(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) --------- UNCAUGHT EXCEPTION --------- java.lang.NullPointerException at com.cosylab.vdct.VisualDCT.oKButton_ActionPerformed(Unknown Source) at com.cosylab.vdct.VisualDCT.connEtoC47(Unknown Source) at com.cosylab.vdct.VisualDCT.access$8100(Unknown Source) at com.cosylab.vdct.VisualDCT$IvjEventHandler.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) at java.awt.Dialog.show(Dialog.java:1082) at java.awt.Component.show(Component.java:1655) at java.awt.Component.setVisible(Component.java:1607) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.cosylab.vdct.VisualDCT.showNewDialog(Unknown Source) at com.cosylab.vdct.events.commands.ShowNewDialog.execute(Unknown Source) at com.cosylab.vdct.events.CommandManager.execute(Unknown Source) at com.cosylab.vdct.graphics.DrawingSurface.mouseClicked(Unknown Source) at com.cosylab.vdct.util.DoubleClickProxy.mouseClicked(Unknown Source) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
ANJ, 17 Sep 2016 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
