1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long string command to device
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 20 Sep 2016 14:17:58 +0200
Thanks for the fast answer.
Then the problem must be of a different kind (I am rather new to EPICS).
I have the following database records:
record(stringout, "$(P):RAW") {
  field(DTYP, "stream")
  field(DESC, "RAW lakeshore communication")
  field(OUT, "@Huginn.proto setRAW $(PORT) $(ADDR)")
  field(SCAN, "Passive")
record(waveform, "$(P):RAW2") {
  field(FTVL, "CHAR")
  field(DESC, "RAW waveform lakeshore record")
with the protocol file:
# /// Raw text string send, if anything is returned it will be in val
setRAW {
  ExtraInput = Ignore;
  out "%s";
  in "%39c";
The stringout record works as expected sending the full string to the LakeShore, while the waveform record does not work, I get the following errors when trying to load the database in iocsh
#Load your database defining the EPICS records
dbLoadRecords(Huginn.db,"P=Huginn,PORT=portA,ADDR=7777")
Record "Huginn:RAW2" does not have a field "OUT"
Error at or before ")" in path "modules/m-epics-Huginn/builddir/db" file "Huginn.db" line 43
iocInit
Starting iocInit
## EPICS R3.14.12.5-2015-08 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Oct  9 2015
2016/09/20 14:10:45.741826 _main_ Huginn:RAW2: Empty I/O link. Forgot the leading '@' or confused INP with OUT ?
2016/09/20 14:10:45.742026 _main_ Huginn:RAW2: Record initialization failed
Sorry for the lengthy mail,
Best
    Bo
On 2016-09-20 13:10, Mark Rivers wrote:
Hi Bo,
The waveform record can be used for both input and output.
This is from the documentation for StreamDevice for the waveform record:
If FTVL=="CHAR" or FTVL="UCHAR":
     In this case, the complete waveform is treated as a large single string of size NORD. No separators are printed or expected.
     Output: x=range(VAL,0,NORD)
        The first NORD characters are printed, which might be less than NELM.
     Input: VAL=x, NORD=length(x)
         A maximum of NELM-1 characters can be read. NORD is updated to the index of the first of the trailing zeros. Usually, this is the same as the string length.
______
__________________________________
From: [email protected] [[email protected]] on behalf of Bo Jakobsen [[email protected]]
Sent: Tuesday, September 20, 2016 3:34 AM
To: [email protected]
Subject: Long string command to device
I am working on modifying an EPICS interface for a LakeShore 336 (LS336)
temperature controller.
In that connection I need to send strings to the LS336 which extends 40
characters.
I found the following thread:
http://www.aps.anl.gov/epics/tech-talk/2016/msg00887.php
which discusses a similar problem, and suggests to use waveform records
and StreamDevice (which I am already using).
However, I am unable to get this to work.
As I read the documentation of waveform records they are only for input,
and hence does not allow to set the OUT field (I am using EPICS 3.14)
Can anyone help with a solution to this problem?
Best
Bo Jakobsen
RE: Long string command to device michael.abbott
Long string command to device Bo Jakobsen
RE: Long string command to device Mark Rivers
Prev: QUERY palak shimpee
Next: RE: Long string command to device michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Long string command to device Mark Rivers
ANJ, 20 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
