1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Archive Appliance Backends
To: "Kasemir, Kay" <[email protected]>, William Cork <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 21 Sep 2016 14:37:29 +0000
Hi
Footnote on Cassandra Archiver from a happy user:
Cassandra Archiver has been superseded by "Cassandra PV Archiver"
http://oss.aquenos.com/cassandra-pv-archiver/
Cassandra PV Archiver does not inherit from RDB Archiver (as its predecessor did) but it was newly designed from scratch.
-- it is pluggable in terms of that user can write custom control system support which implements front-end and back-end interfaces.
Release v 3.0.x reads Channel Access PVs and writes to Apache Cassandra cluster.
-- built-in retrieval interface offers JSON (and there is CSS plugin counterpart)
-- It implements retention and compression of archived samples
-- it is designed to be deployed as a cluster of engines which cooperate on-line. It is horizontally scalable.
Cheers,
Tomas
Od: [email protected] [[email protected]] za uživatele Kasemir, Kay [[email protected]]
Odesláno: 21. září 2016 12:57
Komu: William Cork; [email protected]
Předmět: Re: Archive Appliance Backends
Hi:
>This is my first EPICS tech-talk post.
Welcome
>Has anyone created an alternative backend to PB files?
>I'm looking into utilising a time series database instead
Good question.
I am not aware of that being available for the Archive Appliance.
The archive appliance code started out using the code for the archive engine that's in the CS-Studio repository, see
That one originally uses a relational database (MySQL, Oracle or postgres) for data storage, which is very reliable but not fast.
The code that actually writes to the RDB is in plugs that can be replaced with another type of storage.
There is, for example, an implementation that uses Apache Cassandra, see
The archive appliance has by now deviated quite a lot from the original archive engine that's in the CS-Studio repository because it has a much nicer web interface and some amount of self-maintenance.
I don't know if this means that the underlying storage is still somewhat "pluggable" so that you could replace the custom
collection of protobuf files with for example Cassandra.
Kay
Archive Appliance Backends William Cork
Re: Archive Appliance Backends Kasemir, Kay
Prev: Re: module for Keithley 6485 PA-meter Johnson, Andrew N.
Next: Re: Archive Appliance Backends Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Archive Appliance Backends Kasemir, Kay
ANJ, 21 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
