1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS Boy Write PVs to file
Date: Thu, 22 Sep 2016 13:33:57 +0000
This means waiting a little
should fix your problem:
pv = PVUtil.createPV(widget.getPV)
time.sleep(0.1)
value = PVUtil.getDouble(pv)
Waiting three seconds solved the problem and I can now access the PVs.
The PV needs to connect. If you get the value right away, you’ll receive a null because the PV has not connected and not received the initial value, yet.
Waiting via a delay will often be sufficient, but
a) You should not wait within the script, i.e. on the UI thread, because otherwise you’ll next ask:
    Why does all of CSS freeze while my script is sleeping?
b) Sometimes you need to wait 3 seconds instead of 0.1.
    Better would be to add a listener to the PV which gets notified as values arrive.
A file dialog box is part of the process, so I may be able to have the wait conducted in the background while the user selects a file.
Thank you for the help.
Re: CSS Boy Write PVs to file Konrad, Martin
Re: CSS Boy Write PVs to file Kasemir, Kay
Prev: Re: CSS Boy Write PVs to file Konrad, Martin
Next: RE: CSS Boy Write PVs to file Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CSS Boy Write PVs to file Mark Rivers
Next: Re: CSS Boy Write PVs to file Konrad, Martin
ANJ, 22 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
