> This all works well, and I have mmap() access to registers on the FPGA for
> low speed applications. Now I need to send megabytes of data from the
> FPGA into EPICS PVs, as quickly as I can. I have a FIFO-based solution that
> does around ~100 kB/s (as long as EPICS is quick enough to keep the FIFO
> from filling up). But this isn't nearly fast or robust enough for some
> applications we'd like to support. I played with the AXI DMA, but I don't
> know how to tell Linux to allocate physical memory that the DMA can write
> to. (Dan Paskvan mentioned that you were using the MIG to talk to
> memory. Is this better or easier than DMA?)
Driver support for physical memory requires a bit of a dance, but it's not too hard. I follow this recipe for my drivers, and it works well:
1. Use
void *buf = (void *) __get_free_pages(GFP_KERNEL, N);
to allocate 2^N pages of contiguous physical memory. This returns an unsigned long, but you'll want to immediately cast to to a void* -- this is the pointer to the memory in kernel space.
2. Create a "DMA mapping" for this block of pages:
size_t buf_size = 1 << (N+PAGE_SHIFT);
dma_addr_t dma_addr = dma_map_single(dev, pages, buf_size, DMA_FROM_DEVICE)
This returns the physical address of the allocated buffer.
3. Hand the dma physical address over to the device (write dma_addr to a device register).
Now you're neally ready to roll, but you need to watch your step with cache management. The following recipe seems to work. For each transfer from hardware to memory follow this procedure:
1. Call
dma_sync_single_for_device(dev, dma_addr, buf_size, DMA_FROM_DEVICE);
I'm not sure if this call is necessary.
2. Trigger DMA transfer from your device, wait until all transfer is complete before moving to the next step.
3. Call
dma_sync_single_for_cpu(dev, dma_addr, buf_size, DMA_FROM_DEVICE);
This is the crucial call. Without this when you come to read from buf you'll risk getting stale data.
4. Copy your data from the buffer, for example with
copy_to_user(user_buf, buf + offset, copy_count);
This will be in the .read method of your driver.
If you want to skip the extra copy of step 4, the procedure is *much* harder, and I've never done it. I think you either have to figure out how to hand a contiguous block of pages over to user space, or else support scatter gather and mapping of user allocated pages. Don't bother.
- RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Mooney, Tim M.
- RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
- Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Pete Jemian
- Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe D Peter Siddons
- Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Steve Shoaf
[no subject] Paramveer Jain
areaDetector plugin with multiple outputs Hinxx
<2016>
<2016>
