1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector plugin with multiple outputs
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 23 Sep 2016 14:05:43 +0200
Hi Mark,
thanks for confirming this!
Cheers,
Hinko
On 09/23/2016 02:04 PM, Mark Rivers wrote:
Hi Hinko,
To answer my own question, I think the NDPluginTimeSeries::doTimeSeriesCallbacks() does what I'm after.
Yes, that is correct.  Each NDArray callbacks is done with a different asyn "addr".  So the plugin must pass the flag ASYN_MULTIDEVICE in the constructor and downstream plugins must subscribe for callbacks using the appropriate "addr".
This is a search to see what plugins call doCallbacksGenericPointer with a non-zero final argument:
NDPluginCircularBuff.cpp:              doCallbacksGenericPointer(preBuffer_->readFromStart(), NDArrayData, 0);
NDPluginCircularBuff.cpp:                doCallbacksGenericPointer(preBuffer_->readNext(), NDArrayData, 0);
NDPluginCircularBuff.cpp:          doCallbacksGenericPointer(pArrayCpy, NDArrayData, 0);
NDPluginColorConvert.cpp:    doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
NDPluginFFT.cpp:    doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginFile.cpp:    doCallbacksGenericPointer(pArray, NDArrayData, 0);
NDPluginFile.cpp:      doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginOverlay.cpp:    doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
NDPluginProcess.cpp:        doCallbacksGenericPointer( pArrayOut, NDArrayData, 0);
NDPluginROI.cpp:    doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
NDPluginROIStat.cpp:      doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginStats.cpp:            doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
NDPluginTimeSeries.cpp:    doCallbacksGenericPointer(pArrayOut, NDArrayData, numSignals_);
NDPluginTimeSeries.cpp:      doCallbacksGenericPointer(pArray, NDArrayData, signal);
NDPluginTransform.cpp:  doCallbacksGenericPointer(transformedArray, NDArrayData,0);
NDPosPlugin.cpp:      doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
So of the standard plugins in ADCore only NDPluginTimeSeries does this.
From: [email protected] [[email protected]] on behalf of Hinxx [[email protected]]
Sent: Friday, September 23, 2016 6:44 AM
To: [email protected]
On 09/23/2016 10:41 AM, Hinxx wrote:
I would like to have a single input array into areaDetector plugin and have the plugin deliver multiple arrays as output. Is this possible? Are there any examples?
I would then like to feed the output arrays into other areaDetector plugins.
Hinko
areaDetector plugin with multiple outputs Hinxx
Re: areaDetector plugin with multiple outputs Hinxx
RE: areaDetector plugin with multiple outputs Mark Rivers
Prev: RE: areaDetector plugin with multiple outputs Mark Rivers
Next: Re: areaDetector plugin with multiple outputs Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 23 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
