1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epics4
From: "Mezger Anton Christian (PSI)" <[email protected]>
To: bob dalesio <[email protected]>
Date: Thu, 6 Oct 2016 09:53:01 +0000
Hi Bob,
No, I am using only c++ code and I am starting to think that things are not really the way I expected. Perhaps not everything is yet ready. One of the problems I experience also is that my channelrequester works fine when killing the ioc and starting it again (I get reconnected). However when I was never connected and the channels get therefore destroyed, I cannot reconnect again. Also I should be able to have something similar to ca_add_arry_event and ca_clear_event in order to suspend the data monitoring.
This is all very new to me, many simple examples exists, but do not give you the possibility to write a more complex client plugin with the functionality off a complete epics3 plugin; perhaps my lack of knowledge?
Best regards
Anton
Sent: Donnerstag, 6. Oktober 2016 11:42
To: Mezger Anton Christian (PSI)
Subject: Re: epics4
Hi Anton,
Are you using the EPICS Java IOC? This was an idea for making all new data stores. I am not a fan of this one. THere is also QSrv that compliments the EPICS Process Database. It provides a PVAccess connection to the current process database.
Bob
On Thu, Oct 6, 2016 at 5:25 AM, Mezger Anton Christian (PSI) <[email protected]> wrote:
how one should define description, limits in the new epics4 ioc? Actually the example only defines pv’s without anything else.
Anton
epics4 Mezger Anton Christian (PSI)
Prev: epics4 Mezger Anton Christian (PSI)
Next: RE: epics4 soft ioc david.hickin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epics4 Marty Kraimer
ANJ, 06 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
