1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: StreamDevice fails to compile for RTEMS targets.
To: "Rivers, Mark L." <[email protected]>, "'Michael Westfall'" <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Thu, 6 Oct 2016 17:30:33 +0000
You don't have to build sscan if you don't need the swait record. (You probably don't.  The calcout record is better.) If you don't have the sscan module, you must comment out the line that defines SSCAN, eg.
SSCAN=$(SUPPORT)/sscan-2-10-2
in calc/configure/RELEASE.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Thursday, October 06, 2016 12:24 PM
To: 'Michael Westfall'; [email protected] Talk
Hi Mike,
That error is not in StreamDevice, it is in calc.  calc depends on sscan, so you must install and build sscan before you build calc.
From: [email protected] [mailto:[email protected]] On Behalf Of Michael Westfall
Sent: Thursday, October 06, 2016 12:23 PM
To: [email protected] Talk
Subject: StreamDevice fails to compile for RTEMS targets.
StreamDevice 2.6 fails to compile for RTEMS targets.
The problem seems to be with the example IOC in src/StreamDeviceApp/streamApp.
We get errors like these:
/home/mikew/epics/support/calc/lib/RTEMS-beatnik/libcalc.a(swaitRecord.o): In function `special':
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:553: undefined reference to `recDynLinkClear'
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:531: undefined reference to `recDynLinkAddInput'
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:539: undefined reference to `recDynLinkAddOutput'
/home/mikew/epics/support/calc/lib/RTEMS-beatnik/libcalc.a(swaitRecord.o): In function `inputChanged':
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:832: undefined reference to `recDynLinkGet'
/home/mikew/epics/support/calc/lib/RTEMS-beatnik/libcalc.a(swaitRecord.o): In function `pvSearchCallback':
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:911: undefined reference to `recDynLinkConnectionStatus'
etc....
However, if I set the build to avoid cross compile targets, it builds OK for the Linux host.
Also it builds OK even for RTEMS targets if I comment out CALC=.... in .../configure/RELEASE.
Wondering if anyone else has run across this and what the solution might be..
Mike Westfall
Control Systems Software Engineer
Image removed by sender.
StreamDevice fails to compile for RTEMS targets. Michael Westfall
RE: StreamDevice fails to compile for RTEMS targets. Mark Rivers
Prev: RE: StreamDevice fails to compile for RTEMS targets. Mark Rivers
Next: Fwd: StreamDevice fails to compile for RTEMS targets. Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 06 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
