1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: pvput
To: <[email protected]>, <[email protected]>
Date: Thu, 13 Oct 2016 17:31:16 +0000
Hi Anton,
I guess you’re running pvaSrv/testTop.
Your pvput command is completely correct. The problem is that pvaSrv doesn’t support putting to fields other than value (or value.index for enums).
The second problem is that I’ve checked the code and display.description is never filled in with anything (and never has been).
The other fields of display are filled in correctly, so you can put to them by putting to the appropriate record field. So you can do this, for example:
$ pvput float03.LOPR 2
$ pvget -r "display.limitLow" float03
float03
structure
    structure display
        double limitLow 2
Dave
From: [email protected] [mailto:[email protected]] On Behalf Of Mezger Anton Christian (PSI)
Sent: 06 October 2016 17:00
To: [email protected]
Subject: pvput
trying to set a description with pvput
pvput –r “field(display.description)” float03 “hello”
I get the message [ChannelPutRequesterImpl] message[Logic Error unknown field to put, error)
However this field exist and is seen by pvget
What am I doing wrong again?
Regards
Anton
pvput Mezger Anton Christian (PSI)
Prev: RE: Granville-Phillips 830 Vacuum Quality Monitor Heesterman, Peter J
Next: Question about epics and pcaspy running in one computer lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvput Marty Kraimer
Next: StreamDevice fails to compile for RTEMS targets. Michael Westfall
ANJ, 13 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
