1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Using text/graphic object to block a widget
Date: Mon, 17 Oct 2016 16:42:51 +0000
Dear colleagues,
It has been suggested by multiple colleagues that one can control the visibility of a text object to block the access of a widget under certain conditions. However, when I tried it turns out text/graphic objects are always behind the widgets so even when they are visible they do not block the widget. I also could not control the visibility of any of the widget. I tried it both in MEDM and in caQTDM.
Is it by design that that this function is impossible or I did it wrong?  Thanks.
Best,
Yuelin
_________________________
X-Ray Science Division
Argonne National Laboratory
Phone: 630 252 7863
Adjunct
Dynamics Compression Sector
Washington State University
RE: Using text/graphic object to block a widget Mooney, Tim M.
Prev: Re: archive engine Kasemir, Kay
Next: RE: Using text/graphic object to block a widget Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Write data to SNMP-based devices Priller, John
ANJ, 17 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
