Dear Kay Kasemir,
Yes, the problem was related to metadata data type. Once the limit was
configured to "double precision" instead of "REAL", no error was reported
even when I tried to archive all the PVs.
I deeply appreciated all your support!
Caizhen
-----Original Message-----
Sent: Monday, October 17, 2016 5:13 AM
To: Caizhen Liu; [email protected]
Cc: 'Ben Penaflor'; 'Ikenna Anyanetu'
Subject: Re: archive engine
Hi:
I got the following error in the log file
/var/opt/codac/css/archive-engine-CODAC/console.log.
org.csstudio.archive.engine.model.WriteThread (run) - Error, will try to
reconnect
org.postgresql.util.PSQLException: ERROR: value out of range: underflow
.. at
org.csstudio.archive.writer.rdb.NumericMetaDataHelper.insert(NumericMetaData
Helper.java:84)
Is this related to our EPICS IOC?
The code in question is
https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/ar
chive/archive-plugins/org.csstudio.archive.writer.rdb/src/org/csstudio/archi
ve/writer/rdb/NumericMetaDataHelper.java#L60, which tries to write the
numeric meta data of a channel, i.e. the units, limits etc.
For some reason your relational database doesn't like some of the values.
The RDB table into which the metadata is written should be the num_metadata
table based on this definition:
chive/archive-plugins/org.csstudio.archive.rdb/dbd/postgres_schema.txt#L245
Not 100% sure of the meaning of "value out of range: underflow" for
Postgres, but it could mean that one of the limit values is too small for a
"REAL". Note that the "sample" table has been updated in 2013 to use "double
precision" instead of "REAL" for a data type.
Maybe the num_metadata table also needs to use "double precision" instead of
"REAL"?
Ideally, you could update the sources to print the channel name on the
exception, so you'd see what channel is causing the problem.
-Kay
- FW: archive engine Caizhen Liu
- Re: archive engine Kasemir, Kay
- RE: archive engine Caizhen Liu
RE: Using text/graphic object to block a widget Li, Yuelin
Re: archive engine Konrad, Martin
<2016>
<2016>
