1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA connection problems between VxWorks and Windows
To: EPICS Techtalk <[email protected]>
Date: Mon, 31 Oct 2016 12:09:04 +0100
Hi everyone,
we finally found out what caused this strange behaviour. There was
indeed a misconfiguration in the network: a new device was mistakenly
copnfigured to use the same IP address as the IOC. For reasons that
remain mysterious to me this condition was/is not detected by our
network administrators. Instead we found out by trial and error and a
bit of luck: someone had the idea to unplug the IOC and then issue a
ping (which was answered by the 'imposter'). If the new device had been
configured to not answer pings we would still be wondering...
Cheers
Ben
On 05.08.2016 17:23, Benjamin Franksen wrote:
> We have a PC with Windows 7 that has Labview and an EPICS base 3.14.12.2
> installed. This PC connects to several channel access servers. The
> servers that are Linux based, like a channel access gateway and a
> softioc, make no problems. However, since last week, connections to a
> vxWorks IOC are no longer possible.
> "cainfo" for a PV on this IOC replies something like "connection reset
> by host", although the correct host is mentioned. So it seems that the
> name resolution request for the PV works but the connection to actually
> transmit the data is interrupted or can't be established at all. Both
> systems are within the same network collision domain.
> A Linux channel access client in the same network has no problems with
> it's connections to the same PVs, so it doesn't seem to be a server
> related problem.
> Now, if we change the IP address on the windows PC to another free
> address in the network, channel access first works. Everything is fine
> but only for 3 to 5 minutes. Then connections to the vxWorks IOC fail
> again. Setting the IP address to a third variant has the same effect.
> Everything works but only for a few minutes. Setting the IP address back
> to the original one still doesn't work. Deactivating and  re-activating
> the network interface doesn't help. After a while, maybe  15 to 30
> minutes, an IP address that didn't work and wasn't used for that time,
> can be used again, but still, only for 2 to 3 minutes.
> Setting EPICS_CA_ADDR_LIST to the IP of the IOC and
> EPICS_CA_AUTO_ADDR_LIST to "no" doesn't help. But channel access on the
> windows PC is not completely broken. Requesting PVs from our linux
> based channel access gateway or a linux soft-IOC always works.
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: CA connection problems between VxWorks and Windows Michael Davidsaver
CA connection problems between VxWorks and Windows Benjamin Franksen
Prev: areaDetector and ADCore R2-5 released Mark Rivers
Next: Re: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA connection problems between VxWorks and Windows Hartman, Steven M.
Next: Re: CA connection problems between VxWorks and Windows Michael Davidsaver
ANJ, 31 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
