Hi Keith,
I concur with the others, that particular change won't help gateways.
There was a change to the CAS that might help gateways a little though
iff they are being used to transport large arrays where the amount of
data included is smaller than the maximum array size (i.e. waveform
records that have NORD << NELM). I *think* this just needs a rebuild of
the gateway against the new Base, but hopefully Ralph Lange will confirm
that no code changes are needed in the gateway itself to take full
advantage of that update. Your CA clients should also be using
Base-3.14.12 or later, and be subscribing for dynamic-sized arrays.
- Andrew
On 11/03/2016 04:23 PM, Keith Thorne wrote:
> Dear Andrew (and others)
> At LIGO, we appreciate the changes for faster loading of databases.
> Question: do any of these changes (and the use of dbPvdTableSize shown below) relevant to EPICS gateways?
> We have some very busy gateways (> 100,000 PVs) at present.
> Thanks
> Keith Thorne
>> On Nov 3, 2016, at 10:27 AM, Andrew Johnson <[email protected]> wrote:
>> Hi Murali,
>> On 11/02/2016 06:21 PM, Shankar, Murali wrote:
>>>>> The 3.15 branch does contain a major performance improvement to the IOC
>>>>> when loading large numbers of database records.
>>> Awesome, I can load 100K PV's into a softIOC in a couple of seconds!
>>> Thank you so much!
>> If you are loading large numbers of records also make sure that you are
>> setting the size of the IOC's hash-table before dbLoadDatabase() or
>> dbLoadRecords() in your startup script. The size argument must be a
>> power of 2 up to 64K:
>> dbPvdTableSize(65536)
>> The default size is 512, although we should probably increase that
>> nowadays. More hash buckets means more efficient name searches both at
>> load-time and by the CA name resolution task.
>> - Andrew
>> Arguing for surveillance because you have nothing to hide is no
>> different than making the claim, "I don't care about freedom of
>> speech because I have nothing to say." -- Edward Snowdon
> Keith Thorne <[email protected]>
> CDS Software Engineer
> LIGO Livingston Laboratory
> Livingston, LA 70754
> Phone: (225)686-3168 Fax: (225)686-7189
- Re: EPICS Base Release-Candidate Double Feature! Bruce Hill
- Re: EPICS Base Release-Candidate Double Feature! Shankar, Murali
- Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
- Re: EPICS Base Release-Candidate Double Feature! Keith Thorne
Re: EPICS Base Release-Candidate Double Feature! Michael Davidsaver
<2016>
<2016>
