We are having problems with IOC crashing when a device connected by an IP socket is unavailable. For example, in the startup script is a line like: drvAsynIPPortConfigure("temp", " 172.16.5.218:10010") and a StreamDevice record that uses that IP port when it calls it's protocol. If we unplug the ethernet cable from the device (or just power it off) the IOC crashes after a short while. No error is emitted on the console to indicate that the connection has failed.
So, I'm wondering if there is something we need to do in setting up the AsynIPPort or the StreamDevice protocol file in order to gracefully handle the case where the socket disappears and can't be reconnected to....
-- Mike Westfall
Control Systems Software Engineer
- RE: StreamDevice/AsynIPPort question Mark Rivers
RE: Native NI LabVIEW/EPICS integration Mark Rivers
<2016>
Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
<2016>
ANJ, 07 Dec 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
