1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mutex lock assertion failure
To: "'Christian Pulvermacher'" <[email protected]>, tech-talk <[email protected]>
Date: Mon, 14 Nov 2016 20:31:12 +0000
Hi Christian,
The failure indicates to me a problem in your code, because it should not happen.  The failure is happening in pasynManager->lockPort().  Is your code calling that function explicitly?
Is the failure reproducible?
Is this on Linux?  If so, you can generate a core file and run gdb on it to get a traceback.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Christian Pulvermacher
Sent: Sunday, November 13, 2016 11:35 PM
To: tech-talk
Subject: mutex lock assertion failure
Hello,
I encountered the following assertion failure in one of our IOCs. Is this EPICS-internal, or something  that can originate from our own code?
> A call to 'assert(status == epicsMutexLockOK)'
> by thread 'jtag:dhh.hll0' failed in ../../asyn/asynDriver/asynManager.c line 1694.
> EPICS Release EPICS R3.14.12.5-belle2 $Date: Tue 2015-03-24 09:57:35 -0500$.
> Local time is 2016-11-09 10:44:18.525347533 JST
> Please E-mail this message to the author or to [email protected]
Kind regards,
Christian
RE: mutex lock assertion failure Christian Pulvermacher
Prev: RE: FLOOR function in EPICS CALC error rory.clarke
Next: Re: OS X edm/medm openmotif woes J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: mutex lock assertion failure Christian Pulvermacher
Next: RE: mutex lock assertion failure Christian Pulvermacher
ANJ, 15 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
