1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn daemon + console + log
To: "'Benoit RAT'" <[email protected]>, "[email protected] list" <[email protected]>
Date: Mon, 28 Nov 2016 16:40:12 +0000
We use procServ to handle tasks 1 and 3, and logrotate for task 2.  A simple etc/init.d script can be used to start the procServ/IOC.
https://sourceforge.net/projects/procserv/
From: [email protected] [mailto:[email protected]] On Behalf Of Benoit RAT
Sent: Monday, November 28, 2016 10:06 AM
To: [email protected] list
Subject: Asyn daemon + console + log
Hi guys,
I was wondering if someone could help me implement the following:
  • Already done: I need to start my Asyn IOC as a daemon so that it is executed at startup (A simple /etc/init.d/ scripts is doing the job)
  • Already done: I need to store all the outputs of my IOC into a file (into /var/log/asyn/xxxxx.log with a logrotate to avoid getting a problem with size)
  • I want the user able to connect to the epics-ioc console (Maybe through /dev/ttySxx)
I have manage to get the two first thing working but I can not get the combination of the three. Someone has an idea, is it possible to access to the console?
Maybe running the IOC as a daemon is not the best solution, but I would really like to have my IOC started when I power on my rack.
Image removed by sender.
Benoit RAT LAMY
fix. (+34) 958 285 024
e-mail: [email protected]
www.sevensols.com
Re: Asyn daemon + console + log Rod Nussbaumer
Asyn daemon + console + log Benoit RAT
Prev: SNL sequencer apparently losing connection to underlying network Kevin Meyer
Next: Channel Archiver - Data Conversion / Export from File to RDBArchiver PostgreSQL database Zumbruch, Peter Dr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Asyn daemon + console + log Benoit RAT
Next: Re: Asyn daemon + console + log Rod Nussbaumer
ANJ, 28 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
