1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS/RTEMS Compilation errors
To: <[email protected]>
Date: Mon, 28 Nov 2016 11:32:31 -0600
On 11/28/2016 08:49 AM, Jianxun Yan wrote:
> RTEMS version 4.11.
> EPICS base3-15.1
I believe the libCom OS-interface layer in all released versions of
EPICS Base is only compatible with the API for RTEMS 4.10 and doesn't
have code in it for ARM CPUs either.
Heinz Junkes is working on a port of Base for RTEMS 4.12 (actually for
RTEMS 4.11.99 which is the development branch for 4.12), but the core
developers haven't discussed his changes much yet and they aren't ready
to merge at this point. That discussion should be taking place at
https://code.launchpad.net/~junkes/epics-base/adap-rtems4.12/+merge/311305
If you're interested in helping with this porting effort we would happy
to have the additional help. Detailed discussions that are not directly
related to Heinz's code should take place on the core-talk mailing list.
- Andrew
Re: EPICS/RTEMS Compilation errors Jianxun Yan
Prev: Re: Asyn daemon + console + log Keith Thorne
Next: Re: EPICS/RTEMS Compilation errors Jianxun Yan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS/RTEMS Compilation errors Jianxun Yan
ANJ, 28 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
