1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: sscan module difficulties with EPICS 3.15 base
To: [email protected]
Date: Wed, 30 Nov 2016 14:11:57 -0700
Hello folks,
As a very part-time recreational user of EPICS (really only with Mark Rivers' MCA application), you will have to excuse an unhealthy amount of ignorance that is sure to besmirch the ensuing concern of mine.  With that disclaimer out of the way...
I am trying to install the MCA application, its required modules, and EPICS R3.15.5 on a Windows 10 64-bit PC.  When attempting to build the sscan module, required by MCA, the errors below are produced, beginning with the inability to find tsDefs.h (it does not exist in R3.15).
I'm aware that sscan is not explicitly said to be compatible with R3.15, but only R3.14.  And that is probably why the tsDefs.h error arises.  My question to knowledgeable users is whether there might be a simple fix (commenting out the tsDefs.h line?) or whether my only realistic option is to install the older EPICS base.
Carl Willis
505-412-3277
saveData_writeXDR.c
../saveData_writeXDR.c(200): fatal error C1083: Cannot open include file: 'tsDefs.h': No such file or directory
c:\epics\base/configure/RULES_BUILD:229: recipe for target 'saveData_writeXDR.obj' failed
make[3]: *** [saveData_writeXDR.obj] Error 2
make[3]: Leaving directory 'C:/epics/support/sscan-2-10/sscanApp/src/O.windows-x64'
c:\epics\base/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory 'C:/epics/support/sscan-2-10/sscanApp/src'
c:\epics\base/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory 'C:/epics/support/sscan-2-10/sscanApp'
c:\epics\base/configure/RULES_DIRS:84: recipe for target 'sscanApp.install' failed
make: *** [sscanApp.install] Error 2
RE: sscan module difficulties with EPICS 3.15 base Mark Rivers
Prev: Re: SNL sequencer apparently losing connection to underlying network Benjamin Franksen
Next: RE: sscan module difficulties with EPICS 3.15 base Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS Support in IPAC 2.14 for Acromag IP520? Andrew Johnson
ANJ, 30 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
