1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Capturing data from string which is sent by device
To: "'PilkyuJung'" <[email protected]>
Date: Mon, 5 Dec 2016 15:40:12 +0000
Hi Pilkyu,
I have read the manual for the MPC that you sent.  Indeed it should never sent the unprintable characters like \377\372.  I see that you are using a TCP connection to the MPC, which means you are using its internal Lantronix terminal server.  I think you may have some setting on the Lantronix wrong, for example the start bits, stop bits, or parity.  Can you open a Web page to the Lantronix and see what settings you are using?
Since you have already built the ip application you could try simply using the devMPC device support and see if that works.
To test, comment out the StreamDevice support and add this line to your startup script:
dbLoadRecords("$(IP)/ipApp/Db/MPC.db","P=10MeV:,PUMP=TM:,PORT=P1,PA=5,PN=1")
Your application must have been built using ipSupport.dbd and ip.lib.
Note also that you have an error in your startup script.  You need to define the macro parameter S
dbLoadRecords("db/devvacuum.db","P=10MeV:,R=TM:,PORT1 =P1 ,A=1")
macLib: macro S is undefined (expanding string record (stringin,
"$(P)$(S):message") {
filename="../dbLexRoutines.c" line number=321
macExpandString failed for file db/devvacuum.db
Bad character '$' in record name "10MeV:$(S,undefined):message"
-----Original Message-----
Sent: Sunday, December 04, 2016 11:14 PM
To: Mark Rivers
Cc: [email protected]
Subject: Capturing data from string which is sent by device
Hi, Mark
Here is complete communication with the controller, including both what
is sent as well as what is received.
-----------------------------------------------------------------------------------------------------------------------------------communication
with device
#!../../bin/linux-x86_64/vacuum
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocvacuum")
epicsEnvSet("TOP","/home/anothel/Desktop/vacuum")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("ASYN","/usr/local/epics/extensions/src/synApps_5_7/support/asyn-4-21")
epicsEnvSet("STREAM","/usr/local/epics/extensions/src/synApps_5_7/support/stream-2-6")
epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/anothel/Desktop/vacuum/db"
epicsEnvSet "P" "10MeV:"
epicsEnvSet "R" "TM:"
epicsEnvSet "TCP1" "169.254.90.249:10001"
cd /home/anothel/Desktop/vacuum
dbLoadDatabase "dbd/vacuum.dbd"
vacuum_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("P1",169.254.90.249:10001,0,0,0)
asynSetTraceIOMask("P1", -1, 0x2)
asynSetTraceMask("P1", -1, 0x9)
cd /home/anothel/Desktop/vacuum/iocBoot/iocvacuum
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Nov 22 2016
## Start any sequence programs
#seq sncxxx,"user=anothel"
epics> 2016/12/05 14:01:29.868 169.254.90.249:10001 read 6
\377\373\001\377\373\003
2016/12/05 14:01:29.869 169.254.90.249:10001 write 13
~ 05 0b 1 00\r
2016/12/05 14:01:29.902 169.254.90.249:10001 read 21
\377\372,j`\377\36005 OK 00 7.0E-
2016/12/05 14:01:29.923 169.254.90.249:10001 read 12
10 TORR AE\r\000
2016/12/05 14:01:29.922938 P1 dbPut:
10MeV:TM:ST_x_Pressure_R1(10MeV:TM:ST_x_Pressure_R1.VAL, DBF_STRING,
"��,j`��05 OK 00 7.0E-10 TORR AE") failed
2016/12/05 14:01:31.869 169.254.90.249:10001 write 13
~ 05 0b 1 00\r
2016/12/05 14:01:31.901 169.254.90.249:10001 read 21
\377\372,j`\377\36005 OK 00 7.1E-
2016/12/05 14:01:31.922 169.254.90.249:10001 read 12
10 TORR AF\r\000
2016/12/05 14:01:31.921777 P1 dbPut:
"��,j`��05 OK 00 7.1E-10 TORR AF") failed
2016/12/05 14:01:33.869 169.254.90.249:10001 write 13
~ 05 0b 1 00\r
2016/12/05 14:01:33.901 169.254.90.249:10001 read 21
2016/12/05 14:01:33.922 169.254.90.249:10001 read 12
10 TORR AE\r\000
2016/12/05 14:01:33.921827 P1 dbPut:
-----------------------------------------------------------------------------------------------------------------------------------.db
file
record(stringin, "$(P)$(R)ST_x_Mdl1"){
field( DESC, "Get Model")
field( DTYP, "stream")
field( INP, "@devvacuum.proto getMDL $(PORT1) $(A)")
#field( PINI, "YES")
record( ai, "$(P)$(R)ST_x_Pressure_R1"){
field( DESC, "Pressure read")
field( INP, "@devvacuum.proto getPRS $(PORT1) $(A)")
#field( PREC, "3")
field( EGU, "TORR")
#field( HOPR, "3.5")
#field( LOPR, "0")
field( SCAN, "2 second")
record (stringin, "$(P)$(S):message") {
-----------------------------------------------------------------------------------------------------------------------------------.proto
file
InTerminator=CR;
OutTerminator=CR;
ExtraInput=Ignore;
Terminator = CR LF;
getMDL{
ExtraInput=Ignore;
out "~ 05 01 00 ";
#out "7e 20 30 35 20 30 31 20 30 30 0D";
in "";
getPRS{
out "~ 05 0b 1 00";
in "%E TORR";
@mismatch {in "%(\1)39c";}
As you said, this sentence "\377\372,j`\377\360" is meaning something
wrong while communicate between device and me.
I don't know why I received that line which I didn't want. and I watched
a manual for searching about that number, the manual says nothing for
that number. I attached the manual. While I am writing this mail, I saw
some of strange things in my files. but I can't find and fix it.. Could
you give me a favor? I hope remove "��,j`��". Thank you.
P.S. If I want to know about function of "@mismatch" where I can find
direction or example?
Best Regards,
Pilkyu Jung
Re: Capturing data from string which is sent by device Eric Norum
Prev: Simultaneous Channel access matthew.taylor
Next: Re: Capturing data from string which is sent by device Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Capturing data from string which is sent by device Pilkyu Jung
ANJ, 05 Dec 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
