Hi Bruce,
I replied you here https://github.com/paulscherrerinstitute/pcaspy/issues/29#issuecomment-265103000
I carried out the described test procedure on a SL6 64bit Linux PC. The problem appears definitely in a few seconds.
Best
Xiaoqiang
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Dienstag, 6. Dezember 2016 04:15
To: [email protected]
Subject: Re: deadlock in pcas 3.14.12.6-rc1
Hi Xiaoqiang,
Do you have a pcaspy example that I can run to reproduce this?
I'm running pcaspy 0.6.2 currently, but could also build from a github branch if available.
- Bruce
On 11/10/2016 08:59 AM, Wang Xiaoqiang (PSI) wrote:
> Hi,
> I am testing the support of dynamic array in the recent base 3.14.12.6-rc1.
> Using a normal pcaspy application, which updates ~15 Hz. It repeatedly gets into a deadlock state.
> The analysis has been put up here
> The solution could be reversing the lock order during
> casEventSys::process. But it does not seem to be easy, because the chain of calls involved.
> Best
> Xiaoqiang
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
- Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
- deadlock in pcas 3.14.12.6-rc1 Wang Xiaoqiang (PSI)
RE: Simultaneous Channel access matthew.taylor
Re: Epics V4 Questions - New to Epics 4 Marty Kraimer
<2016>
2025
<2016>
2025
