1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: streamdevice 2.7.7 and PINI
To: Hinxx <[email protected]>, tech-talk <[email protected]>
Date: Tue, 6 Dec 2016 13:17:13 +0000
You could do
asynSetTraceIOMask(...)
asynSetTraceFile(...)
asynSetTraceMask(...)
on the underlying asyn port before iocInit.  By sending the trace output to a file it has a minimal impact on timing.  You can then see if some operations are timing out.
From: [email protected] [[email protected]] on behalf of Hinxx [[email protected]]
Sent: Tuesday, December 06, 2016 2:04 AM
To: tech-talk
Subject: streamdevice 2.7.7 and PINI
I have 29 stream records with PINI fields set to YES and three of them
show
'Value: VByteArray[[], size 0, INVALID(TIMEOUT_ALARM), 2016/12/06
08:59:18.108]'
No errors are seen in IOC. My proto is not setting any timeout
variables, I guess defaults are used.
If I use 25 records or less with PINI=YES this is not happening.
What limit am I hitting?
Hinko
streamdevice 2.7.7 and PINI Hinxx
Prev: Re: Epics V4 Questions - New to Epics 4 Marty Kraimer
Next: Re: IOC segfaults with epicsMutexLock (pmutexNode=0x0) Blaz Kranjc
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: streamdevice 2.7.7 and PINI Hinxx
Next: TPG-256 driver Peredkov, Sergey
ANJ, 06 Dec 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
