Hi, I have something more to add .... I could add asyn record in the VDCT database. There was no problem till the point of adding asyn records and building (make) the application But when I executed st.cmd (using <app>.exe , on win32 PC), first I got the error "asyn.dll not found". So I added the path of asyn.dll to the system variable PATH. Now when I execute st.cmd , I get the following error : "The procedure entry point WSAPoll could not be located in the dynamic link library WS2_32.dll" I tried adding the path of this dll to the system PATH but the I keep getting the same error on executing st.cmd Any Clues about this problem ? (Note : No such error was seen when I added Calc module for acalcout & scalcout records, I just had to add path of calc.dll to PATH) Thanks, Stefen On Mon, Jan 2, 2017 at 7:28 PM, Mark Rivers <[email protected]> wrote: Hi Stefen, Thanks, Stefen
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
