Subject: Asyn and devices with changing register map
To: EPICS Tech Talk <[email protected]>, Mark Rivers <[email protected]>
Date: Fri, 6 Jan 2017 22:30:43 +0000
Hi Mark,
I am intending to implement a driver for an FPGA-based device based on
asynPortDriver. I am wondering how to deal with devices which are under
heavy development resulting in frequent changes to their register map.
In this context I am looking for a simple and clean way to tie records
to a certain address.
In a world without Asyn I would implement a driver that simply reads the
address and the type of a register from the INP/OUT fields of my
records. This could be changed easily (even by an FPGA engineer) without
recompiling the driver and all configuration data is in the record
definition. Note that I'm fine with this slightly harder to read data in
the INP/OUT field. Usually the record's name, the description field, and
if necessary additional comments provide sufficient information about
what the address stands for.
Using Asyn it seems like I need to populate Asyn's paramList which in
the case of most drivers seems to be a hard-coded mapping between names
and addresses. Are there any drivers that populate this dynamically on
IOC start from a configuration file or even from the EPICS database file?
Thanks a lot,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: Asyn and devices with changing register map Michael Davidsaver
RE: Asyn and devices with changing register map Mark Rivers
Re: Asyn and devices with changing register map Dirk Zimoch
Prev: Asyn: example driver for slow device? Konrad, Martin
Next: Re: Asyn and devices with changing register map Michael Davidsaver
Prev: RE: Asyn: example driver for slow device? Mark Rivers
