Subject: ASYN VXI-11
To: Mark Rivers <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Tue, 10 Jan 2017 09:58:45 -0800
I’m attempting to communicate with a Keysight 53210A frequency counter using VXI-11/ASYN/StreamDevice.  I’m seeing all sorts of problems when the driver attempts to set up the SRQ link — to the point where the windows application on the frequency counter crashes and puts up a ‘.exe failed’ message (upside down!) on the instrument screen.
I had a look at the code in drvVxi11.c and by moving the SRQ code inside the ‘isGpibLink’ test everything seems to work.  This change also gets VXI-11 communication working with some other instruments that also failed before.
What are your thoughts on this change?
Does anyone use SRQ with non-'GPIB' devices?  If so, how did you make it work?
diff -U50 -r ../asyn4-30.orig/asyn/vxi11/drvVxi11.c ./asyn/vxi11/drvVxi11.c
--- ../asyn4-30.orig/asyn/vxi11/drvVxi11.c 2016-08-23 09:23:36.000000000 -0700
+++ ./asyn/vxi11/drvVxi11.c 2017-01-10 09:19:06.969887000 -0800
@@ -909,102 +909,102 @@
     pvxiPort->server.lid = link;
     pvxiPort->server.connected = TRUE;
     pvxiPort->ctrlAddr = -1;
     if(pvxiPort->isGpibLink) {
         /* Ask the controller's gpib address.*/
         status = vxiBusStatus(pvxiPort,
             VXI_BSTAT_BUS_ADDRESS,pvxiPort->defTimeout,&pvxiPort->ctrlAddr);
         if(status!=asynSuccess) {
             asynPrint(pasynUser,ASYN_TRACE_ERROR,
                "%s vxiConnectPort cannot read bus status initialization aborted\n",
                 pvxiPort->portName);
             if (pvxiPort->server.connected)
                 vxiDisconnectPort(pvxiPort);
             return status;
         /* initialize the vxiPort structure with the data we have got so far */
         pvxiPort->primary[pvxiPort->ctrlAddr].primary.lid = link;
         pvxiPort->primary[pvxiPort->ctrlAddr].primary.connected = TRUE;
         /* now we can use vxiBusStatus; if we are not the controller fail */
         status = vxiBusStatus(pvxiPort, VXI_BSTAT_SYSTEM_CONTROLLER,
             pvxiPort->defTimeout,&isController);
                 "%s vxiConnectPort vxiBusStatus error initialization aborted\n",
             return status;
         if(isController == 0) {
             status = vxiBusStatus(pvxiPort, VXI_BSTAT_CONTROLLER_IN_CHARGE,
                 return asynError;
                     "%s vxiConnectPort neither system controller nor "
                     "controller in charge -- initialization aborted\n",
                 return asynError;
+        vxiCreateIrqChannel(pvxiPort,pasynUser);
-    vxiCreateIrqChannel(pvxiPort,pasynUser);
     pasynManager->exceptionConnect(pvxiPort->pasynUser);
     return asynSuccess;
 static asynStatus vxiDisconnectPort(vxiPort *pvxiPort)
     int          addr,secondary;
     asynUser     *pasynUser = pvxiPort->pasynUser;
     if(!pvxiPort->server.connected) {
             "%s vxiDisconnectPort but not connected\n",pvxiPort->portName);
         return asynError;
     if(pasynUser) asynPrint(pasynUser,ASYN_TRACE_FLOW,
         "%s vxiDisconnectPort\n",pvxiPort->portName);
     if(!pvxiPort->isSingleLink)
     for(addr = 0; addr < NUM_GPIB_ADDRESSES; addr++) {
         devLink *pdevLink;
         pdevLink = &pvxiPort->primary[addr].primary;
         if(pdevLink->connected) {
             if(addr!=pvxiPort->ctrlAddr) {
                 vxiDestroyDevLink(pvxiPort, pdevLink->lid);
                 vxiDisconnectException(pvxiPort,addr);
             pdevLink->lid = 0;
             pdevLink->connected = FALSE;
         for(secondary = 0; secondary < NUM_GPIB_ADDRESSES; secondary++) {
             pdevLink = &pvxiPort->primary[addr].secondary[secondary];
                 vxiDisconnectException(pvxiPort,(addr*100 + secondary));
                 pdevLink->lid = 0;
     vxiDestroyIrqChannel(pvxiPort);
     vxiDestroyDevLink(pvxiPort, pvxiPort->server.lid);
     pvxiPort->server.connected = FALSE;
     pvxiPort->server.lid = 0;
     clnt_destroy(pvxiPort->rpcClient);
     pasynManager->exceptionDisconnect(pvxiPort->pasynUser);
     return asynSuccess;
 static void vxiReport(void *drvPvt,FILE *fd,int details)
Eric Norum
[email protected]
Re: ASYN VXI-11 Ben Franksen
Prev: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Rivers
Next: Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
Prev: Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
Next: Re: ASYN VXI-11 Ben Franksen
