Subject: RE: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME
Date: Wed, 11 Jan 2017 08:05:39 +0000
Dear Mark,
Thanks a lot for this prompt answer.
The hardware is almost ready: we use Galil controller (type DMC-2183 , 8axis) also the motor controllers are delivered and the crates will be installed in the control racks soon.
Scientific Linux is the platform used on control machines at SESAME
-          The number of motors in the FE and OP are listed in the table below.
The beamline has standard components for XAFS beamline type; actually these are components that were used in the ROBL beamline at ESRF.
-          At the experimental station we have a 5 axis optical table with 5 motors (3 jacks + 2 translations) and a 6 axis sample manipulator .
For detection, we will be using IC with femto current amplifier DPLCA type (or similar) and a ketek single SDD with the SCA (xia, DXP mercury).
For end users software we can start with something very simple for stop and go scanning of the energy (XAFS) and simple XRF data (single emission lines and may be saving files in a format that can be read by PyMCA. The on-the-fly scanning mode is not a priority for the moment.
Your help will be highly appreciated
Many thanks,
Component
MOTOR
Gear
Lead Screw
Encoder
Limits
Stepper
Ratio
Pitch
Driver
Type
Model
Full
Type
Resolution
steps/Rev
Filter (FI)
Ver
1
Stepper Motor
McLennan 23HS-304
200
2:1 Belt
1mm
Not-Equipped
Not-Equipped
Positive & Negative & 4 Positions
2 Phase Bipolar
White Beam Slits (WBSL)
SVU
2
Stepper Motor
Berger Lahr VRDM 597/50 LNC
500
1:01
3mm
TWK-Elektronik CRP 65-4096G
4096/360 Deg
Positive & Negative
5 Phase
SVD
3
Stepper Motor
500
1:01
3mm
TWK-Elektronik CRP 65-4096 G
4096/360 Deg
Positive & Negative
5 Phase
SHL
4
Stepper Motor
500
1:01
3mm
4096/360 Deg
Positive & Negative
5 Phase
SHR
5
Stepper Motor
500
1:01
3mm
4096/360 Deg
Positive & Negative
5 Phase
FE beam Shutter (ABS)
SHV
6
Pneumatic
Vertical Collimating Mirror (VCM)
JK1
7
Stepper Motor
McLennan 23HS-309
200
50:01:00
2 mm
Heidenhain MT 60 K
0.5 µm
Positive & Negative & Differential
2 Phase Bipolar
JK2
8
Stepper Motor
McLennan 23HS-309
200
50:01:00
2 mm
Heidenhain MT 60 K
0.5 µm
2 Phase Bipolar
JK3
9
Stepper Motor
McLennan 23HS-309
200
50:03:00
2 mm
Heidenhain MT 60 K
0.5 µm
2 Phase Bipolar
Hor
10
UHV Stepper
AML B23.2
200
1:01
1 mm
Not-Equipped
Not-Equipped
Positive & Negative
2 Phase Bipolar
BND (bender)
11
Pneumatic
White Beam Wire Monitor (WM1)
Ver
12
Magnet Stepper
Portescap P850-508 C11
200
4:1 Belt
2 mm
Heidenhain LS 476
0.5 µm
Positive & Negative
2 Phase Bipolar
Double crystal Monochromator (DCM)
Bragg
13
DC Servo
McLennan
DC Motor
Not-Equipped
Not-Equipped
Heidenhain RON806
0.0001°
Positive & Negative & Datum
DC Servo
(ɵ)
Driver
JK1
13
Stepper Motor
McLennan 34HS-311E
200
25:01:00
5mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
JK2
14
Stepper Motor
McLennan 34HS-311E
200
25:01:00
5mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
JK3
15
Stepper Motor
McLennan 34HS-311E
200
25:01:00
5mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
Primary
Stepper Motor
McLennan 34HS-209E
200
Not-Equipped
1mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
Yaw
Roll
Pico Motor
New Focus 8301-UHV-KAP
Pico Motor
Not-Equipped
0.3175 mm
Not-Equipped
Not-Equipped
Not-Equipped
Picomotor Driver
Adjustment
Yaw
Pico Motor
Pico Motor
Not-Equipped
0.3175 mm
Not-Equipped
Not-Equipped
Not-Equipped
Picomotor Driver
Adjustment
Pitch
16
Pico Motor
Pico Motor
Not-Equipped
0.3175 mm
Not-Equipped
Not-Equipped
Not-Equipped
Picomotor Driver
Adjustment
Pitch Fine
17
Piezo Translator
Queensgate DPT-C.
Piezo Translator
Not-Equipped
Not-Equipped
Not-Equipped
Not-Equipped
Datum
Piezo Driver
Roll Fine
18
Piezo Translator
Queensgate DPT-C.
Piezo Translator
Not-Equipped
Not-Equipped
Not-Equipped
Not-Equipped
Datum
Piezo Driver
C2Y
19
UHV Stepper
AML C17.1
200
0.5 mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
C2Z
20
UHV Stepper
AML C17.1
200
0.5 mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
C2B (bender)
21
Monochromatic Beam Slits (MBSL)
SVU
22
Stepper Motor
McLennan 23HS-304E
200
2:1 Belt
1 mm
Not-Equipped
Not-Equipped
Positive & Negative & Zero
2 Phase Bipolar
SVD
23
Stepper Motor
McLennan 23HS-304E
200
2:1 Belt
1 mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
SHL
24
Stepper Motor
McLennan 23HS-304E
200
2:1 Belt
1 mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
SHR
25
Stepper Motor
McLennan 23HS-304E
200
2:1 Belt
1 mm
Not-Equipped
Not-Equipped
2 Phase Bipolar
Monochromatic Beam Wire Monitor (WM2)
Ver
26
Magnet Stepper
200
4:1 Belt
2 mm
Heidenhain LS 476
±0.5 µm
Positive & Negative
2 Phase Bipolar
Vertical Focusing Mirror (VFM)
JK1
27
Stepper Motor
McLennan 23HS-309
200
50:01:00
2 mm
Heidenhain MT 60 K
0.5 µm
2 Phase Bipolar
JK2
28
Stepper Motor
McLennan 23HS-309
200
50:01:00
2 mm
Heidenhain MT 60 K
0.5 µm
2 Phase Bipolar
JK3
29
Stepper Motor
McLennan 23HS-309
200
50:03:00
2 mm
Heidenhain MT 60 K
0.5 µm
2 Phase Bipolar
Hor
30
UHV Stepper
AML B23.2
200
1:01
1 mm
Not-Equipped
Not-Equipped
Positive & Negative
2 Phase Bipolar
BND
31
Pneumatic
Beam Position Monitor (BPM)
VF (Foils)
32
Stepper
VD (dectors)
33
Stepper
Messaoud
-----Original Message-----
Sent: Tuesday, January 10, 2017 5:51 PM
To: Messaoud Harfouche
Cc: [email protected]
Subject: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME
Could you list more specifically the hardware on the beamline (motor controllers, counter/timers, other detectors, etc.). What computer platform will you use, and what are the requirements for the end user software?
Sent from my iPhone
On Jan 10, 2017, at 5:01 AM, Messaoud Harfouche <[email protected]<mailto:[email protected]>> wrote:
Dear EPICS community
The SESAME light source project is very close to having first beam in the storage ring. This would be first for Science in the  Middle East. It now faces the unfortunate situation that first beamlines are not ready. As part of completing the XAFS /XRF beamlines there is work to do in delivering the beamline controls system.
I would like to ask if someone is prepared to help work with SESAME to delivering the initial beamline control system. I am thinking it will take a substantial part of 6 month of someone’s effort, with a latter phase needing to be at SESAME. I realise that controls and software effort is tight for many projects, but for SESAME to achieve an operational beamline is monumental step. I think this could be achieved with support and agreement from a lab management or as an individual.
Immediate needs are basic motor control with some pseudo motors for optics in addition to the implementation of the detector readings to EPICS such as our SCA DXP mercury from XIA. This could start by working remotely than through visiting SESAME, outside Amman in Jordan,  supported by SESAME for implementation debugging/refinements.
Many thanks for considering this.
Regards.
Dr. Messaoud Harfouche
XRF/XAFS Beamline Scientist/Manager
Synchrotron-light for Experimental and Scientific Applications in the Middle East (SESAME)
P.O. Box 7, Allan 19252, Jordan,
Tel: +962 5 3511348, ext. 303
Mobile: +962 7 98932327
Fax: +962 53511423
Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Messaoud Harfouche
Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Rivers
Prev: Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
Next: Problems with vxWorks IOCs on base 3.14.12.6 Mark Rivers
Prev: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Rivers
Next: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Clift
