Subject: RE: Problems with seq 2.2.4 on Windows
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Fri, 13 Jan 2017 11:02:49 +0000
Hi Mark,
snl.c is autogenerated using the lemon parser and lemon was updated between 2.2.3 and 2.2.4
Looking at the code failing it is:
    }else{
      assert( yyact == YY_ERROR_ACTION );
      yyminorunion.yy0 = yyminor;
#ifdef YYERRORSYMBOL
      int yymx;
#endif
I think Visual Studio 2010 doesn’t like the declaration of  yymx  occurring after an assignment, this wasn’t allowed prior to the C99 standard I believe. If you edit the corresponding place in snl.lt and move the yymx declaration to before the assert does it them generate an snl.c that compiles OK?
Freddie
Sent: 13 January 2017 00:30
To: Mark Rivers; 'Benjamin Franksen'; Akeroyd, Freddie (STFC,RAL,ISIS)
I should add that seq 2.2.3 builds OK with the same setup, so I have reverted to that for now.
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, January 12, 2017 6:06 PM
To: 'Benjamin Franksen'; [email protected]
Subject: Problems with seq 2.2.4 on Windows
Hi Ben and Freddie,
I am having problems building seq 2.2.4 on Windows:
-          Visual Studio 2010
-          EPICS 3.15.5
-          windows-x64 and windows-x64-static architectures
This is the complete output when building.
make -C J:/epics/support/seq-2-2-4 install
make[1]: Entering directory 'J:/epics/support/seq-2-2-4'
make -C ./configure install
make[2]: Entering directory 'J:/epics/support/seq-2-2-4/configure'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../..
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/configure/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/convertRelease.pl checkRelease
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/configure/O.windows-x64-static'
make[2]: Leaving directory 'J:/epics/support/seq-2-2-4/configure'
make -C ./src install
make[2]: Entering directory 'J:/epics/support/seq-2-2-4/src'
make -C ./pv install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/pv'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../../..
make -C O.windows-x64-static -f ../Makefile TOP=../../.. \
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/pv/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m pv.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        pv.obj ../pv.c
cl                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3        -MT    -I. -I../O.Common -I. -I. -I.. -I../../../include/compi
ler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -
c ../pv.c
pv.c
lib -nologo -verbose -out:pv.lib        pv.obj
Appending pv.obj
"Installing library ../../../lib/windows-x64-static/pv.lib"
mkdir ../../../lib/windows-x64-static
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/pv/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/pv'
make -C ./common install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/common'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/common/O.windows-x64-static'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/common/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/common'
make -C ./seq install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/seq'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/seq/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_queue.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../..
/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_queue.obj ../seq_queue.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_cmd.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_cmd.obj ../seq_cmd.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_qry.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_qry.obj ../seq_qry.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_prog.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_prog.obj ../seq_prog.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_mac.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_mac.obj ../seq_mac.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_if.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../in
clude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_if.obj ../seq_if.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_ca.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../in
clude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_ca.obj ../seq_ca.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_task.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_task.obj ../seq_task.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m seq_main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        seq_main.obj ../seq_main.c
c ../seq_main.c
seq_main.c
c ../seq_task.c
seq_task.c
c ../seq_ca.c
seq_ca.c
c ../seq_if.c
seq_if.c
c ../seq_mac.c
seq_mac.c
c ../seq_prog.c
seq_prog.c
c ../seq_qry.c
seq_qry.c
c ../seq_cmd.c
seq_cmd.c
c ../seq_queue.c
seq_queue.c
lib -nologo -verbose -out:seq.lib        seq_main.obj seq_task.obj seq_ca.obj seq_if.obj seq_mac.obj seq_prog.obj seq_qry.obj seq_cmd.obj seq_queue.obj
Appending seq_queue.obj
Appending seq_cmd.obj
Appending seq_qry.obj
Appending seq_prog.obj
Appending seq_mac.obj
Appending seq_if.obj
Appending seq_ca.obj
Appending seq_task.obj
Appending seq_main.obj
"Installing library ../../../lib/windows-x64-static/seq.lib"
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/seq/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/seq'
make -C ./lemon install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/lemon'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/lemon/O.windows-x64-static'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m lemon.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inc
lude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        lemon.obj ../lemon.c
c ../lemon.c
lemon.c
link -nologo   -incremental:no -opt:ref -release  /MACHINE:X64              -out:lemon.exe       lemon.obj       ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
"Installing created executable ../../../bin/windows-x64-static/lemon.exe"
mkdir ../../../bin/windows-x64-static
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/lemon/O.windows-x64-static'
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/lemon'
make -C ./snc install
make[3]: Entering directory 'J:/epics/support/seq-2-2-4/src/snc'
make[4]: Entering directory 'J:/epics/support/seq-2-2-4/src/snc/O.windows-x64-static'
J:/epics/support/seq-2-2-4/bin/windows-x64-static/lemon.exe o=. ../snl.lem
2 parsing conflicts.
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m snl.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inclu
de -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        snl.obj snl.c
re2c.exe -s -b -o lexer.c ../snl.re
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inc
lude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        lexer.obj lexer.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        builtin.obj ../builtin.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../..
/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        sym_table.obj ../sym_table.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../.
./include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        gen_tables.obj ../gen_tables.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../
../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        gen_ss_code.obj ../gen_ss_code.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        gen_code.obj ../gen_code.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        analysis.obj ../analysis.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../..
/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        var_types.obj ../var_types.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../incl
ude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        node.obj ../node.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64-static/mkmf.pl  -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../incl
ude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        main.obj ../main.c
c lexer.c
lexer.c
../snl.re(90) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(91) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(93) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(138) : warning C4267: '=' : conversion from 'size_t' to 'uint', possible loss of data
../snl.re(213) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
../snl.re(364) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
../snl.re(380) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
../snl.re(431) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
c snl.c
snl.c
./snl.c(2410) : error C2143: syntax error : missing ';' before 'type'
./snl.c(2440) : error C2065: 'yymx' : undeclared identifier
./snl.c(2441) : error C2065: 'yymx' : undeclared identifier
./snl.c(2452) : error C2065: 'yymx' : undeclared identifier
./snl.c(2467) : error C2065: 'yymx' : undeclared identifier
H:/epics/base-3.15.5/configure/RULES_BUILD:229: recipe for target 'snl.obj' failed
make[4]: *** [snl.obj] Error 2
make[4]: Leaving directory 'J:/epics/support/seq-2-2-4/src/snc/O.windows-x64-static'
H:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static' failed
make[3]: *** [install.windows-x64-static] Error 2
make[3]: Leaving directory 'J:/epics/support/seq-2-2-4/src/snc'
H:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'snc.install' failed
make[2]: *** [snc.install] Error 2
make[2]: Leaving directory 'J:/epics/support/seq-2-2-4/src'
H:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory 'J:/epics/support/seq-2-2-4'
H:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'J:/epics/support/seq-2-2-4.install' failed
make: *** [J:/epics/support/seq-2-2-4.install] Error 2
RE: Problems with seq 2.2.4 on Windows Mark Rivers
Re: Problems with seq 2.2.4 on Windows Andrew Johnson
Prev: RE: Problems with seq 2.2.4 on Windows Mark Rivers
Next: EPICS Device Support for cRIO and FlexRIO FPGA based devices is now available Enrique Bernal
Next: RE: Problems with seq 2.2.4 on Windows Mark Rivers
