Subject: Re: CA server bind failure on Windows
To: Ben Franksen <[email protected]>
Date: Sun, 15 Jan 2017 19:01:39 +0100
Hi Ben,
On Sun, Jan 15, 2017 at 3:37 AM, Ben Franksen <[email protected]> wrote:
Am 12.01.2017 um 19:04 schrieb [email protected]:
> [...] suggests another application/service might have bound to the port
> already with SO_EXCLUSIVEADDRUSE and this appears to be the situation
> (the National Instruments network variables server process in this
> case).
This is very nasty behaviour on part of NI. The CA ports 5064 and 5065
are registered with the IANA and officially belong to Channel Access
(both UDP and TCP), see
https://www.iana.org/assignments/service-names-port-numbers/service-names-port-numbers.txt.
IMO you should file a complaint with NI; they should change their
default port to some unregistered port, perhaps they want to register
their protocol with IANA under another port number, but simply hijacking
an existing registered port is not acceptable.
Careful...
NI's LabVIEW network variables server has a plugin that contains their implementation of the Channel Access server, see http://www.ni.com/white-paper/13865/en/. While their CA server has a couple of flaws and issues and doesn't fully behave like the EPICS CA servers (e.g. by presumably using SO_EXCLUSIVEADDRUSE), using the Channel Access ports for Channel Access is definitely legitimate and recommended.
Cheers,
~Ralph
Re: CA server bind failure on Windows Benjamin Franksen
CA server bind failure on Windows freddie.akeroyd
Re: CA server bind failure on Windows Ben Franksen
Prev: RE: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Next: Re: Asyn and devices with changing register map Dirk Zimoch
Prev: Re: CA server bind failure on Windows Ben Franksen
Next: Re: CA server bind failure on Windows Benjamin Franksen
